262xp - How far would you drive?
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, Jul 24, 2014.
  1. clemsonfor
    You can soak it in diesel fuel it dissolves lots of carbon and crud
    HoneyFuzz likes this.
  2. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Does it have the plastic clutch cover? IIRC the chip deflectors are different between the plastic and metal covers. There were two different base gaskets used in the 262 a thin one and a way fat one. I have both here. As far as the chain catcher goes, I routinely retap those to M6, not a big problem but you may need a 'reduced head height' M6 so as not to interfere with the chain.
    clemsonfor and HoneyFuzz like this.
  3. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    As for the chain catcher.. I always find the threads all wore out. For some reason i couldnt find my tap... So for my recent Husky 261 i drilled it out... Went into my huge array of saved bolts,screws and such... Found a thin head small lil bolt.. And a thin nut to put on the backside. Worked pretty slick !!
    clemsonfor likes this.
  4. Jon1270
    Jon1270
    Pittsburgh, PA
    It's the plastic clutch cover, which has a slot behind the clutch that looks like it could accept the dust flap.
    I'll have to tap the chain catcher on this one. There's not enough clearance between the case and the handle for me to be comfortable putting a nut back there.
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    I think some version of Poulan also used that same deflector but Cut4Fun can verify that.
  6. Cut4fun
    Cut4fun
    OHIO Redneck
    No poulans I know of for the 262 rubber dust deflector. Same one used in 154 254 257 262 I think.
  7. HittinSteel
    HittinSteel
    Wooster, Ohio
    clemsonfor and Cut4fun like this.
  8. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Checked chainsawr.com for the deflector, none to be had.
  9. clemsonfor
    Yea thats where the deflector would go...bit thats all I know. I bow out to the other guys knowledge base now
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    ereplacementparts had the deflector, I just forgot to add it to the order.
    Cut4fun likes this.
  11. clemsonfor
    Do your E replacement part orders take weeks to get to you? I ordered a non cat muffler for a quake saw and it said it would be like 2 weeks to get it. I wasnt in a hurry and did not care bit it did take weeks. I joke and said all they do is when you order a part they order it from the manufacture in china then once they get it they ship too you.
  12. Jon1270
    Jon1270
    Pittsburgh, PA
    Deflector ordered. Thanks for the tip, C4F.
    For items they have in stock, ereplacementparts is generally pretty good. Special orders can take a while.
