Wood stove pipe install question
Discussion in 'Modern EPA Stoves and Fireplaces' started by cootcraig, Apr 8, 2021.
  1. cootcraig
    cootcraig
    E. of Pueblo, Colorado
    I would like to replace my pellet stove with a wood stove. My current choice is a Woodstock Ideal Steel Hybrid. I have approached my favorite local stove dealer about installation. I'm not sure where else to look for an installation design. The steep roof on this story and a half house would seem to complicate a vertical pipe. What are your thoughts. The home is just east of Pueblo, CO.
    exterior-pellet-stove-pipe-1.JPG exterior-pellet-stove-pipe-2.JPG interior-pellet-stove.JPG room-above-alcove-knee-wall.JPG room-above-knee-wall-crawl-space.JPG room-above-stove.JPG
  2. cootcraig
    cootcraig
    I just called another stove dealer. He suggested putting vertical pipe above the stove to 18" below the ceiling, out the wall, and then more vertical pipe outside.
  3. Slocum
    Slocum
    North Central Indiana
    My basement install is through the wall type of install. If I had it to do over I would do whatever I had to do to go straight up.
    fox9988, wildwest and T.Jeff Veal like this.
  4. cootcraig
    cootcraig
    What don't you like about the through the wall install?. I'm thinking vertical only as well. I don't know if vertical is realistic at this point.
    wildwest, Slocum and T.Jeff Veal like this.
  5. cootcraig
    cootcraig
    This crawl space is above the stove, maybe not straight above the stove outlet though.
    It seems to me the pitch of the roof will complicate the install. How high would the pipe have to go?
  6. Wolley
    Wolley
    Couple ideas. 1. Put the new stove somewhere else in the house that's easier to install. 2. If the new stove is in the same corner, the pipe from the stove to the ceiling doesn't have have to be vertical. A little angle might be enough to put the install in the crawl space.
  7. cootcraig
    cootcraig
    Given the layout of the house, I don't think there is another good spot for install. The pellet stove (Quadrafire 1100i) is able to heat the house comfortably in the coldest weather we've had over the last three years.
    Yes, I think a little offset angle will allow the stove pipe to be centered in the second floor crawlspace.
    I'm a novice at this. I then wonder how the external pipe can be supported to the proper height.
  8. Slocum
    Slocum
    Draft issues. My house is really tight and I fight my basement stove when 30 or warmer. My upstairs stove pipe is straight up and the difference is night and day. Chimney caps are same height on both stoves.
    wildwest and brenndatomu like this.
  9. chris
    depending on the pipe mfg they do make external roof supports for tall flues.
  10. brenndatomu
    Basement installs are always more problematic than a stove on the main floor.
    My main concern would be finding a storm collar for the chimney with a roof that steep. Might take some custom made parts.
    I'd go out the wall personally.
    Slocum and wildwest like this.
  11. wildwest
    Nice to meet you cootcraig :) My husband does roofing and goes back to the same house every other year to repair the roof and straighten out the stove pipe coming out of a steep roof. The spring snows build up against it or, slide into it. How much snow does Pueblo get, and being down there I imagine it's wet and heavy.
    First suggestion to that home owner was to move the pipe, but it's a vacation home they rarely visit and instead pay repairs when go there :loco: :crazy:
    Design? You might need either a bigger hearth or ember protection, wood stoves need more clearance than pellet stoves. And for Brendy's remark above how about a 45* up higher on the wall then vertical like your pellet stove pipe?
  12. wildwest
    And your home is beautiful!!
  13. cootcraig
    cootcraig
    Today, I tracked down an experienced local stove pipe installer and sweep. I'm sending the above pictures to him, and will likely have him out to inspect and advise.
    fox9988 likes this.
  14. Slocum
    Slocum
    My “basement “ is daylighted on 2.5 sides. It has 2 garage doors and a patio door along with windows. Some may not even call it a basement. My draft is very touchy, I crack the patio door every time I open stove door. Plus I have 24’ of pipe outside, with flue temps being so much lower with modern stoves i wish I would have ran it straight up.
    brenndatomu likes this.
  15. brenndatomu
    How many floors are above your "basement"?
    Slocum likes this.
  16. Slocum
    Slocum
    One floor
  17. Slocum
    Slocum
    Another thing that affects me is my home is surrounded by trees and kinda sits in a low area. Not much wind hits the roof.
