Dry in N.E. Ohio
Discussion in 'Everything Else (off topic)' started by Casper, Apr 7, 2021.
  1. Casper
    Casper
    I think we had some years back in the 80s and 90s that we were in the fields early but can't remember it being dusty while plowing.
    However, I do remember things breaking.
    I went to lift the plows over a grass water way. It seemed fine on the left side, the one I was watching, right side, didn't lift.
    I think they are supposed to be one piece while in working order.
    I'm waiting for the replacement to get here, hopefully soon.
  2. stuckinthemuck
    stuckinthemuck
    Confirmed with UNL.
  3. Casper
    Casper
  4. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Last fall dug some post holes with post hole diggers, the sand at the bottom of the hole was like hitting concrete. Had to pour water in the hole so post hole diggers could pull up the dirt. Cylinder rebuildable or waiting on a new one?
  5. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Very dry here in stark county.
  6. stuckinthemuck
    stuckinthemuck
    Hopefully you get repaired before the monsoon rains come!!!!
  7. Casper
    Casper
  8. schlot
    schlot
    NW Iowa
    We just a nice day long soaker in NW Iowa that the farmers were anxious to see.
    Hope things get better over there.
  9. DNH
    DNH
    Missouri
    Last few years I’ve noticed a prolonged dry season mid spring followed by excessive moisture for weeks at a time during early planting season. We will see if the pattern continues.
  10. jrider
    jrider
    Haven’t had any seriously dry weather here in south Jersey in years
    Backwoods Savage and Casper like this.
  11. oldspark
    oldspark
    NW Iowa
    Your draught chart looks like ours in NW Iowa but getting rain this week, 1.5 so far with more on the way.
  12. Backwoods Savage
    I miss those days of plowing and fitting fields but especially I liked planting. When I was young some of the neighbors used to hire me to plant just because I could plant straight rows. This was back when planting was done with 2 or 4 row planters so it took much longer. It also was back when very few tractors had power steering. What a joy it was to finally get power steering too!
    Greenstick, jrider, oldspark and 4 others like this.
  13. Greenstick
    Greenstick
    Dakotah Territory is really crispy dry ready to burn or blow away and we pray it isn't blowing when it burns. Already over 30,000 acres burned up this year. 1st pic is 2 weeks ago, 40 mph wind and 1/2 mile visibility because of the dust in the air. 2 is our drought map and the green dot is me. 20210329_192133.jpg 20210409_214817~2.jpg
    eatonpcat and Backwoods Savage like this.
  14. Greenstick
    Greenstick
  15. Casper
    Casper
    Yikes! Keep your head on swivel for fire danger.
  16. brenndatomu
    The neighbor was working ground the other day and there was a little dust flying...we did get .6" rain then that night, and supposed to get more today, so that will provide a nice start for any seed that gets planted...seems a bit early for that, but I bet the soil temp is warm enough after having 75-80* all week (and 55-60* at night)
  17. Casper
    Casper
    We go by lake temp for our ground temp. We like to see 52-54° for row crops. Oats or grass (hay) seeding is in the ground this year. Current temp off CLE is 43. If you get a cold-cool and wet stretch, seeds will rot in the ground.
  18. brenndatomu
    We are always warmer than y'all in the springtime down here an hour from the lake...I've seen some hay drilled in, but nothing else, as of yet.
