The Survival Hybrid Wood Stove
Discussion in 'Modern EPA Stoves and Fireplaces' started by Nordic Splitter, Apr 6, 2021.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    The Most Affordable, High Efficiency
    Wood Stove!
    This little powerhouse is perfect for heating small spaces up to 1,000 sq.ft., has an output of 27,294 BTU's/hr, an efficiency rating of 79.4%, and emissions of 1.05 gm/hr! These combined efficiency and emissions results makes the Survival Hybrid Wood Stove the ideal wood stove for smaller spaces.
    The Survival Hybrid Wood Stove is the smallest, most affordable, wood stove in our lineup! You won't find a better deal on a high quality, made in America, high efficiency, low emissions, wood stove, anywhere else.
    The Survival Stove is an offshoot of our Navajo Project, where the challenge was to design a small combination wood/coal stove that would burn both fuels as cleanly and efficiently as possible. Starts at $1407
    DIMENSIONS & SPECIFICATIONS
    HxWxD (Max.Leg Height): 36.5"x19.5"x26"
    Footprint: 16.5"W x 18.5"D
    Firebox Size: 1.2 Cu. ft.
    Wood Length (Maximum): 16"
    Area Heated: up to 1,000 sq.ft.
    BTU Output: 15,332-27,294/hr (per EPA tests)
    EPA Efficiency: 79.4% (per EPA tests)
    Combustion System: Hybrid (Catalyst & Secondary Air)
    2020 EPA Approved
    EPA Emissions: 1.05 grams/hr (per EPA tests)
    2100 Degree Stainless Foil Catalyst: Standard
    Easy Catalyst Access: Just Lift the Top Lid!
    Cooktop: Standard
    Flue Exit: Top only
    Flue Size: 6"
    Draft Control: Manual
    Burn Time: 6-8 hrs
    Window Size (viewable): 7"H x 6"W Loading Door: Front Only
    Loading Door (WxH): 8"W x 9"H
    Weight: 310 lbs.
    Mobile Home Approved
    Ash Pan: Standard
    Bottom Heat Shield: Standard
    Rear Heat Shield: Standard
    Side Heat Shields: Standard
    Stove Rear Clearance: 9"
    Stove Side Clearance: 9"
    Stove Corner Clearance: 9"
    Minimum Hearth Size: 30"W x 48"D
    UL Listed to 1482
    Thoughts on this one?? Looking for something smaller to heat an area of about 700 sq ft...
  2. Warner
    Eckie and Ohio like this.
  3. Warner
    He has a pretty comprehensive write up about his stove.
    RGrant likes this.
  4. Ohio
    Not Ohio
  5. RGrant
    RGrant
    Connecticut
    OP- a word of caution, I am loooong winded about this stove. Have a read and if there’s anything in particular that you think I could help you with, by all means ask away.
    As my burn season is morphing into the cutting and splitting season again, I’ll be looking for reasons to rest my back I’m sure.
    Eckie likes this.
  6. Eckie
    Eckie
    No RGrant, you are informative and thorough!
    RGrant likes this.
