Echo top handle saw recommendations
Discussion in 'Chainsaws and Power Equipment' started by Easy Livin' 3000, Apr 5, 2021.
  1. Easy Livin' 3000
    Easy Livin' 3000
    North side of the ridge
    Looking to upgrade my small saw, and I think I'll stick with echo, but go from rear handle to top. I'll start with a 14" bar.
    Looking for recommendations for the upgrade. Light and reliable and spunky are the main requirements.
    If you love other small top handle saws, I'm all ears.
    T.Jeff Veal likes this.
  2. Chud
    Chud
    Well I’ve used older echo tophandle saws, I think they were cs3000’s and I’ve used the 2511t. I liked them both.
    I use a Stihl 201tc and a 150t and I like them both.
    You are more limited in the size of wood you can cut with 25cc saws
    Echo makes good top handle saws and they are a less expensive than Stihl.
    Sandhillbilly and T.Jeff Veal like this.
  3. Easy Livin' 3000
    Easy Livin' 3000
    Thank Chud. I think I'd like a little versatility, and as this isn't a climbing saw, the really low weight of a 25 cc saw isn't required. What are your thoughts on a little more firepower?
    Sandhillbilly, T.Jeff Veal and Chud like this.
  4. Chud
    Chud
    I don’t have any recent experience with the bigger echo top handle saws. Most of my experience is with the ms200t 201t. You can easily cut wood up to 16” with them. I use a 16” bar on the 201t. If you want to cut wood over 16”, you should consider 50cc. The Stihl 261c costs less than the 201tc.
  5. Canadian border VT
    That is :loco: :crazy:
  6. Easy Livin' 3000
    Easy Livin' 3000
    Anything over 16" will get handled by the 55cc husky. Heavy, but dead reliable so far, up to 40" to date. So much of my cutting is small wood, so I really like to use a small saw as much as I can.
  7. Haftacut
    Haftacut
    Rives Junction, MI
    Any opinions on the echo top handle the dealer is having you demo T.Jeff Veal I checked one out the other day at the shop and what a nice handling little unit. I could see myself getting used to something like that!
  8. mrfancyplants
    mrfancyplants
    South Carolina
    I sure like my new/used cs-440 I just picked up for $150. 45cc not too heavy. Nimble enough to cut some logs. Runs great with a sharp chain. I had pretty good luck with my Ryobi 3716 too though.
    Edit: not sure that mine is top-handled.
  9. T.Jeff Veal
    If you are cutting small wood, the 2511T Echo is a great little saw. Only top handle I've run. There are things I like/dislike about it. It has the side adjusterfor chain and a GREAT oil pump, the oiler adjust screw is on top which is nice, good power.
    I dont like the Husky style clutch, makes taking chain off a pain.
    Cut a bunch of limbs up to about 7" with it. It has a 12" b/c on it. 0330212046_HDR.jpg
  10. Haftacut
    Haftacut
    Rives Junction, MI
    After having ran 5 tanks through it, do you have a preference between a small rear handle saw and the small top handle?
  11. T.Jeff Veal
    I guess it depends on the task. I really like the top handle cutting limbs on the jig, used it to take down 2 dogwoods today. And I used the MS180 on the bigger pieces, even noodled some. 14"b/c 10722.jpeg 10721.jpeg 10724.jpeg 10723.jpeg
    And I found out the gloves I jad weren't Kevlar and the 2511T will bite you. 10716.jpeg
    Next pic is a bit graphic...got my attention...
    Bad operator error...
    Took a little chunk out. Washed it, cleaned it, antibiotic and a big bandaid 10714.jpeg
    Chud and Haftacut like this.
  12. Haftacut
    Haftacut
    Rives Junction, MI
    I’ll bet you’re glad you at least had the gloves on! Glad you’re alrighto_O
  13. T.Jeff Veal
    Yes sir, and it was safety chain and not new.
