Orange. Needs a carb rebuild. Its at our FD and the L is too rich and it would not idle so I went to adjust out and no change when I closed the L all the way. Went to set it back and the end came off my adjustment tool. I beat it back on and set out to normal and pulled the rope out of the thing!!! Was just asking g so I could look up carb setting.
Carb setting should be 1&1 starting out. I have a whole trash barrel of those things if there is something you need to get it up and running.
Thanks but after I jerked the cord out were sending it out to the shop to get fixed. We have the money.
I think out needs a carb rebuild. The thing is started 12x a yr and then run in a car fire or something once a yr maybe. Looks brand new I think they used E gas and it sits full. So my guess is that they will rebuild carb and jut retie the rope as it looks like the rope pulled out. The Saw was not responding to adjustment. But my dang tool fell apart so when it was running I'm not sure where or what I was doing?
