Order WS Ideal Steel Stove!
Discussion in 'Modern EPA Stoves and Fireplaces' started by snaple4, Apr 2, 2021.
  1. snaple4
    snaple4
    I finally placed the order! Went with the “works” and used one of their designs. I kinda wanted to hold out to see if they end up making a new “Steel of the month” but decided not to. Should be getting it in May. I will make sure to post before and after pictures. Unfortunately, I won’t be able to test it for at least 4 months after install.....
  2. TurboDiesel
    Which design did you go with?
  3. TurboDiesel
    The IS is a heating machine for sure.
    :handshake:
  4. snaple4
    snaple4
    Steam punk #ORN007. Charcoal with metallic grey accents. I got the generic 3 piece tool set and side hanger for IS b/c they are limited on supply for other designs. Also ordered the boot warmers as well. I may eventually order custom designs but it won’t be anytime soon.
    I am actually a bit concerned it will be too big for my house.
  5. TurboDiesel
    You did get the ash pan, right?
  6. Canadian border VT
    don’t be that stove does low N slow really well..
  7. snaple4
    snaple4
    Yes. The Works comes with almost everything. The heat shield, Outside air adapter, and the hanger for the tools are the only extras you have to pay for I think.
    Works includes:
    Ideal Steel Hybrid-Basic Charcoal
    210 Ideal Steel Ash Pan
    210 Soapstone Firebox Liner
    210 Soapstone Side Panels
    210 Design (medallion, burner, andiron) -mixed Gray
  8. Rearscreen
    Rearscreen
    Well now you can go to their September picnic open house at the factory, IF there will ever be another one...
  9. Backwoods Savage
    Did you ask about extending the 6 month guarantee?
  10. Eckie
    Eckie
    Ooohh...is that really a thing? I've been pondering the timeline of ordering and getting the stove in ready for when needed next season and the 6 month guarantee....
    Edit for clarity: as in waiting till just before needing to maximize the "trial period" of the 6 months
  11. snaple4
    snaple4
    No, I haven’t. I may though b/c realistically I won’t actually use it in any meaningful way till late October/early November. I am sure having a new wood stove in May will prompt me to accidentally use the wood stove and a/c at the same time....
    papadave, T.Jeff Veal, Eckie and 3 others like this.
  12. Backwoods Savage
    I had a similar situation so before I bought I asked and they extended it. My guess is they will do it for you too. You will find these folks are very easy to work with.
  13. snaple4
    snaple4
    Got shipping info today! Now prep time. How do I move such a thing without damaging it, myself, the floor, the wall, the kids...?
  14. wildwest
    Check out this thread, lots of ideas on moving it :)
    Finally pulled the trigger...
  15. NVhunter
    NVhunter
    Northern Nevada
    I had to move mine a few weeks ago. Actually sent it back to Woodstock for a repair. If you can find a "narrow" pallet jack put 2, 4x4s between the base of the stove (make sure the ash pan is off and the wood lays against the edge on the bottom of the steel body) and lift the whole stove up. It is a piece of cake to move at that point. I strapped the stove to the pallet jack to extra security as I had to push it up a narrow sidewalk with a slight angle and a turn. Here are a few pictures of how I moved mine. 20210423_110723.jpg 20210423_110717.jpg 20210423_110729.jpg
  16. snaple4
    snaple4
    Thank you everyone for the suggestions on moving it. I am recruiting a few co-workers. Delivery is set for tomorrow. I did have a question about pipe. The way my class A comes down is off enter and close to the back wall. I had the old stove closer to the corner so the pipe 45ed over then went down with another 45. It looked fine. This stove is much wider so I will have it as close to the edge of the tile as allowed. For looks and ease of cleaning, should I try to do a rear exit with a T or will top exit look better?
  17. brenndatomu
    Top vent always drafts better...
  18. snaple4
    snaple4
    that may be true. However, if I have to use a 45 right out of the unit it may not make much difference. Anyone have some good articles about how to measure for pipe?
    brenndatomu likes this.
  19. brenndatomu
    I think you'd still be better off...and if you could pull off using 22.5* fittings, even better.
    papadave and snaple4 like this.
  20. snaple4
    snaple4
    thank you for the link! I’ll hopefully set the stove this weekend and will measure it out. Have a local stove company coming out Monday to give me an estimate but I am leaning towards doing it myself if I can get it set before they close.
    22.5’s would be nice for flow.
