Tree ID help needed
Discussion in 'The Wood Pile' started by JimBear, Mar 27, 2021.
  1. JimBear
    JimBear
    This is at the State Park, a tree service took it down. I initially thought it was Ash till I got up to it. I believe it’s Maple but I have never seen borers/beatles work on Maple. Maybe those are Woodpecker hole but they look quit similar to the bark beetle holes in a lot of the pines around here. The wood is solid so I’m not sure what the woodpeckers would be after.
    6D800C24-1159-41C5-B31F-70B751975B03.jpeg A942871D-946E-487A-978E-7DC5DA3E8110.jpeg 8FBFA12F-FB9C-4928-9B4D-0487F312B9E4.jpeg 0057B68E-D59D-4132-A4AF-58D028CC1A0C.jpeg 0B3A7DDC-7115-465E-926E-40947B881E8A.jpeg
  2. Locust Post
    Could be pignut hickory
  3. JimBear
    JimBear
    Here’s a pic of the leaves I found around it. It cuts like butter & has no distinctive smell. Everything else that I can see close by is Ash, Pine or 1 Cottonwood.
    A073C26B-2049-4DD9-A262-B7711A4F7509.jpeg 9A58E1A9-CE7E-45E7-A6A5-007B2F1376B5.jpeg B9F72636-F5B0-4887-A2A1-4CCD47892F4E.jpeg
  4. Eric VW
    Almost looks like woodpecker damage to me...
    End grain doesn’t look right for pignut (at least pignut here, but I see how the bark could be an indicator).
    Popple or aspen maybe? Never really dealt with either, so not much help.
    Probably burn gooder after drying tho.
  5. Horkn
    I was about to say basswood.
  6. Eric VW
    Good possibility! :yes:
    Another one I can’t speak to.
  7. stuckinthemuck
    stuckinthemuck
    Looks like a poplar variant but could be basswood too. Not Maple. Maple has opposite branching. Those look like woodpecker holes. I actually think the woodpeckers practice some kind of farming near me. Damage the trees, wait for insect infection, harvest the insects.
  8. Buck55
    Buck55
    Rochester, NY
    I think that's what it is.
    FatBoy85, T.Jeff Veal, Horkn and 4 others like this.
  9. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Basswood 100%. I have a few of those here....first glance...hickory. Bump it with your saw....that will tell you for sure.
    FatBoy85, T.Jeff Veal, Horkn and 3 others like this.
  10. JimBear
    JimBear
    A fella on Hearth ID’d as Littleleaf Linden
    Virginia Tech Dendrology Fact Sheet
    L
    inden/basswood/poplar probably all fall in the same category for most folks.
    It fit all the criteria except growing range but being it’s a state park that’s not out of the realm of possibility. I guess I have a nice bunch of fire pit wood now, I post a picture in loaded trucks thread.
  11. huskihl
    huskihl
    Linden and basswood are the same here. We have the big leaf version. Leaves are about 8” across
    Chud, T.Jeff Veal, Horkn and 3 others like this.
  12. buZZsaw BRAD
    I think its basswood as well. Rounds would be lighter than normal. Dries fast and feather light. Ive seen the same sapsucker/woodpecker damage too. Ill look for pics
  13. buZZsaw BRAD
    Basswood leaves from stump sprouts. IMG_0675.JPG Basswood i cut in early January IMG_3715.JPG
  14. amateur cutter
    Well I'd say buZZsaw BRAD nailed it! Good for campfire or a quick hot shoulder season fire.
  15. Backwoods Savage
    Try out your hand with some whittling.
  16. Horkn
    Yes, all the ones I have sure seem like something really nice. Then you cut into it. It's still great SS wood and it splits easily and dries quickly.
  17. Horkn
    I nailed it first. :p
  18. buZZsaw BRAD
    Ive seen that hole pattern on multiple species in my years of scrounging.
  19. Warner
  20. JCMC
    JCMC
    Just outside of Shushan, NY
    Yes it is Basswood and the holes are typical of the Yellow-Bellied Sapsucker.
    FatBoy85, Horkn, T.Jeff Veal and 2 others like this.
