ATV log skidding /hitch
Discussion in 'Chainsaws and Power Equipment' started by bogydave, Oct 26, 2013.
  1. bogydave
    4X4 at bottom has a 2" hole made with a 2" hole saw, 2" deep, chipped out the hole so it fits
    over the ball on ATV. This way the weight is still on the ball, not much on the rack.
    Top 4X4 has a holding bracket so it don't bounce off the ball when the suspension move up.
    Not for fast speed & it does lock up the rear suspension, but at slow speeds, no prob.
    4'" wide inside, 7" outside.
    Bracket to hold it at the top to the rack. Slide the aluminum angle over the rack & ball, slid in the piece of plywood.
    put in the bolts, I go hand tight. Good to go.
    Log splitter hitch
    just cut a piece of a 2X6 down to 4" wide, screwed & braced it a little higher than the log splitter
    tongue , just have to lift it an inch or so to go on the ball,
    I leave it mounted to the ATV & split wood. The tongue jack on the splitter is a finger pinching "mo-fu'r".
    It fold up easy now, out of the way, no pinched finger or fighting to let it down to the ball on the ATV.
    100 atv skid.JPG 100_6036.JPG 100_6037-1.jpg 100_6038.jpg 100_7266.JPG 102_4169.JPG
  2. swags
    swags Moderator
    Very innovative bet that makes it really nice for hauling logs and splitter around.
  3. Certified106
    Certified106
    In The Hills
    Great setup
  4. DexterDay
    Yep... Thinking the same thing.
    My splitter is a Mofo when putting on the Ball now.
    Nice job Dave
  5. bogydave
    It skids logs better than using he atv trailer ball, lifts them higher so the front of the logs don't dig in.
    Gotta pay attention when skidding the big ones, font tires pop up off the ground sometimes.
    Strong enough for moving the empty road trailers around too.
    A lot easier on the yard.
    Just used it to park the trailers out of the way for winter.
    SilentHatch likes this.
  6. Well Seasoned
    Thanks for putting that up Dave! My splitter runs to close to the grizzly. Something like u got will change all that! Great post!
  7. Gasifier
    How is this working out for you Dave? Do you think the wood and connections will hold up? Or do you think you may find one built out of steel would be better? Great idea by the way!
  8. bogydave
    Worked well for 3 years.
    Thought about having an aluminum one made up but
    I think steel or aluminum might be to rigid & too strong.
    Metal might make something on the ATV break.
    I'd rather have the wood break than something on the ATV
    I had to replace the bottom 4x4 when it cracked out.
    The wood absorbs some shock & is like a shear pin.
    Just screws holding it together so it also gives a little.
    Worked this year with no issues & did skid out some 20" heavy logs.
    Gasifier likes this.
  9. Gasifier
    Nice, glad it is working well. Work smarter. Good way to go.
  10. lukem
    Ever consider making a groove where it connects to the top rack so the rack can float freely up and down and not lock up the suspension? You'd probably need something a little more stout than SPF lumber, but good hardwood boards should be able to resist the tendency to split especially if you tied them together at the top. You'd have to make some sort of a strap to hold the 4x4 tight to the ball to keep it from popping off but that wouldn't be hard. You could remove the ball and use a bolt to mount the bottom part.
    My splitter is a muther to get on/off the Honda. Wheels are turning... I need another project like I need a hole in my head though.
  11. bogydave
    Yea tried that, movement problems
    but your idea should work :thumbs:
    Would get wear on the moving part on the rack, but a sleeve over the rack on the wear spots.
    Might have to work on that one
    Good idea,
    better mouse trap :)
  12. lukem
    I was about "this" close to going out and building one last night, but I need to whittle down the honey-do list a little before I go making stuff for my 4-wheeler that I don't really need and won't even use for a couple months.
    I'm thinking a couple bolts with wing nuts at the top of the groove would make things plenty strong.
    Some paste wax on the inside of the groove to keep things moving freely.
    Wrap the rack in electrical tape and then put a sleeve (cut a slit length-ways in some PVC) over it. Might have to use a heat gun to soften it up a little too.
    Paint it all black to match the quad.
  13. bogydave
    You are getting fancy
    Having the suspension work would be a good deal
  14. lukem
    Fancy would be making something that hooks up to the frame...metal and welder and whatnot. This is poor man's engineering with scrap lumber, nuts and bolts, black tape, and PVC pipe.
    DexterDay likes this.
  15. nate
    nate Banned
    Palmer, AK
    Build it in steel and use springs to allow it to move up and down?
    Never weighed a log, but I wouldn't doubt one around 20" would weight in at 2000+ lbs.
  16. bogydave
    Yea
    that would required a welding machine.
    +, wood is my shear pin, I can replace wooden parts.
    papadave likes this.
  17. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    I've skidded a lot of logs with my ATV and your right, getting the end of the log up off the ground makes all of the difference. I need to build something like that.
  18. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Somewhat similar to a 3 point hitch I recently sold for moving gooseneck trailers.
  19. lukem
    Got a pic of that? My BIL wants on to use for his dump trailer.
  20. nate
    nate Banned
    Palmer, AK
    Have a welder, plasma cutter, chop saw and torch at home, same at the shop.
