Back to hoarding.....
Discussion in 'The Wood Pile' started by Greg, Mar 18, 2021.
  1. Greg
    Greg
    As Spring finally arrives, just finished roughing in bowls, ready for some dry time
    pic of lathe, bowls half turned and homemade kiln
    03F42148-995F-40AB-9ADB-D538312A578F.jpeg 2069F66A-49C7-48ED-B13A-5DE28A458DCA.jpeg 7E9E4AA1-8107-4072-A8D9-5AEF7A1B2AA9.jpeg D51B4B53-E43F-40DA-B276-A762CB343CE4.jpeg E00B1762-8840-4F13-A0D8-77F7F31DFA4C.jpeg 3EE0A514-7075-48FE-9F7E-D208C204DFE4.jpeg
  2. Eric VW
  3. Ronaldo
    Ronaldo
    Those are beautiful!! How do you keep them from cracking when they are drying?
  4. The Wood Wolverine
    I’ve often wondered, turning goes better wet, then is it hopes that it won’t crack? I’ve never had anything crack/split but I’ve also always used pieces of salvaged firewood.
    Some great coloration. :yes:
  5. Eckie
    Eckie
    Looks.like you could make lots of fire starters with all those chips/shavings! Can you please ellaborate on your homemade kiln?
  6. Greg
    Greg
    I turn them green but leave an inch thick or walls, then end grain seal them. I weigh and label each piece and then when they stop losing weight and i verify 10-15% moisture I would final turn
    so all these were from stuff I cut green, and can’t say for sure none of them will crack. I have yet to final turn anything I dried myself, I have final turned a couple I bought to get started
  7. Greg
    Greg
    Yes, wet for first turn and then final turn when dry
  8. Greg
    Greg
    The kiln is and old fridge. I cut two air holes in bottom side and then two in top. Regulated with small round covers. It is heated with a 100 watt light bulb
    thermostat controls to shut off light at 90degrees and then Back on at 75. Air is supposed to naturally flow via convection
    I am testing it now. Supposedly you can dry a once turned blank in a month, compared to six months or more of packing one in its own shavings and keeping in a paper bag
    I just followed a YouTube video
    heck, I took one class on turning at woodcraft, and watched a lot of you tube. Still know very little of what I’m doing but figuring it out as I go and thankful to have many options for pieces to work with
  9. buZZsaw BRAD
    Those are really nice Greg! What species? Nice FHC engineering with the fridge kiln. Just dont accidently put a beer in there...coffee okay, beer not so good!
    I had a guy stop and ask for a couple pieces of pin oak i was cutting a couple weeks ago. Turns out he is a turner like you and is looking for logs...he came to the right person. Lives a few houses down from where i process most of my wood so convenient. He was turning a bowl for me too. Gave him a chunk of honey locust, cherry and a black locust burl.
  10. brenndatomu
    Why? Maybe a person of German heritage would enjoy a nice warm beer! :p
    Digging the kiln Greg , and the woodworking! :yes:
  11. buZZsaw BRAD
    Not familiar with German customs? Do they normally drink it warm?
  12. brenndatomu
    Yes and no...they don't like it ice cold like here...more like ~50* instead of the 35-37* preferred by Americans...
  13. Eric Wanderweg
    It depends on what style beer. Typical lagers are served chilled, but not ice cold so that you can't taste them (as in the USA) I hear in the U.K. where ale is king, they like to bring it to a low boil before they partake :cool:
  14. Greg
    Greg
    I drink a few but don’t when I’m around the lathe and bandsaw, figured best not to have any help not knowing what I’m doing
  15. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    I spent some winter hours turning. Hickory knot from the firewood pile with some red epoxy. Great work by the way EBF8A09F-1741-4934-B8B7-0051262ACE65.jpeg
  16. Eckie
    Eckie
    Wow, that tricked my eyes and mind at first.... Before I read the post, I thought it was a wooden platter with a well charred steak that you ate the middle out of!
  17. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    By far the best thing I have ever made. Epoxy pulls out the color and textures for sure!
    Chazsbetterhalf and Eckie like this.
  18. Eckie
    Eckie
    Did you coat the outer (regular "colored" wood) with anything? And that piece looks odd shaped, how did you make it?
    Chazsbetterhalf and Woodsnwoods like this.
  19. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    Skim of epoxy on it, and tung oil. Turned part of the interior, band saw shaped the rest with a ton of sanding. If I turned the entire piece, I would have wiped out a lot of the unique aspects as it is oval in shape. I have another one of these drying out in the garage, unturned
  20. buZZsaw BRAD
    That is cool! Nice work WNW! :thumbs:
