Splitter is finally built
Discussion in 'The Wood Pile' started by Firewood Bandit, Mar 14, 2021.
  1. Firewood Bandit
    Firewood Bandit
    3 years ago I wanted this builder to make me a splitter. He bought a new place and had to build a new shop and being a family man was unable to start building splitters again. I struggled along satisfactorily with a 22 Ton Fast cycle Iron and Oak Commercial unit. It was OK but this one is something special.
    It has a # of features:
    Folding log table to save about 20" of space
    Folding tongue to save about 30" of space
    30" stroke with a limiter to whatever you want it to be. For example if running 16", stop stroke at 19".
    The hydro filter is the same one that goes on JD giant fertilizer machines and is rated for 125 GPM. The assembling goes all to the bottom of the tank and goes through a diffuser. The tank has two more sets of baffles that the fluid has to draw from the bottom. (heat rises)
    Special dump valves to increase flow on return to around 50 GPM
    Handles interestate speeds
    Tons of storage
    Made by Alex of A.E. Metalwerx
    https://www.facebook.com/search/top?q=a e metalwerx
    DSCF0014.JPG DSCF0009.JPG DSCF0010.JPG DSCF0011.JPG DSCF0012.JPG DSCF0013.JPG DSCF0015.JPG DSCF0016.JPG DSCF0017.JPG
  2. Firewood Bandit
    Firewood Bandit
    Everyone likes pics.
    DSCF0018.JPG DSCF0019.JPG DSCF0020.JPG DSCF0021.JPG DSCF0023.JPG DSCF0022.JPG DSCF0024.JPG DSCF0027.JPG DSCF0026.JPG
  3. Ward Hoarder
    Ward Hoarder
    West Virginia
    Nice looking unit you have there.
    Need action picture/video
    WeldrDave, Woodsnwoods, Chaz and 11 others like this.
  4. JRHAWK9
    JRHAWK9
    Wisconsin
    That thing looks sweet! Videos?
    Woodsnwoods, M2theB, Horkn and 6 others like this.
  5. Eric Wanderweg
    Looks like a serious machine there, and the craftsmanship put into it speaks volumes :yes:
    Woodsnwoods, M2theB, Horkn and 7 others like this.
  6. Chvymn99
    Good Lookin' rig....:popcorn:... Keep us updated....
  7. JRHAWK9
    JRHAWK9
    Wisconsin
    man, judging by the size of the rod vs cylinder...the return stroke must be pretty darn fast! :eek:
    Woodsnwoods, Horkn, Chvymn99 and 5 others like this.
  8. Buck55
    Buck55
    Rochester, NY
    Wow! Just Wow! What a beautiful machine!
  9. Firewood Bandit
    Firewood Bandit
    After seeing his work in the past, it was the only builder that was making something way better than the Iron and Oak Commercial I had.
  10. jo191145
    Whens mine coming? Jk
    Nice looking rig there. That should be fun!
    Woodsnwoods, Horkn, Chvymn99 and 4 others like this.
  11. brenndatomu
    Very nice...impressive!
  12. Chris F
    Chris F
    Micksburg, Ontario
    Looks very well built and it looks like you have a lot of work for it. I like the big tank with sight glass and the hose routing. Looks like he put a lot of thought into it.
    Honda engine is tops too.
    Woodsnwoods, Horkn, Chvymn99 and 7 others like this.
  13. Firewood Bandit
    Firewood Bandit
    I can't explain it real well, but 5" x 3.5" rod, with some extra plumbing and dump valve. The builder says it is running over 50GPM on return stroke.
    The thing that really speeds up cycle time though is the stroke limiter. You set the pusher to only go back as far as it needs to be rather than the full 30".
    Woodsnwoods, M2theB, Horkn and 9 others like this.
  14. Ronaldo
    Ronaldo
    Awesome machine.
    Alex is topnotch on design and workmanship.
  15. Firewood Bandit
    Firewood Bandit
    There is a LOT more than meets the eye. The in tank filter is what John Deere uses on the very large industrial giant tired fertilizer spreaders. It is rated at 125GPM. The assembly goes to the bottom of the tank to a diffuser. The tank has 2 baffles and the fluid has to go under the baffle to get to the next chamber. Of course heat rises. This really slows the time it takes to get to the end of the tank where the suction line is, of course on the bottom of the tank.
    Woodsnwoods, Horkn, Chris F and 7 others like this.
  16. Firewood Bandit
    Firewood Bandit
    Yes he is
  17. amateur cutter
    Ok, I think I want one. Call the number on the machine? That looks like a slick set up for sure!
  18. JRHAWK9
    JRHAWK9
    Wisconsin
    I wonder how many calls that poor guy is going to be getting tomorrow. :rofl: :lol:
  19. JRHAWK9
    JRHAWK9
    Wisconsin
    Out of curiosity, do you sell firewood or is this just for personal use to split what you burn?
    Woodsnwoods, Horkn, Chvymn99 and 6 others like this.
  20. Kimberly
    Kimberly
    The Kangaroo State
    Dang, now that is a splitter that any firewood hoarder could be proud to own.
