Playing with moisture meter
Discussion in 'The Wood Pile' started by AmarilloSlim, Jul 27, 2014.
  1. AmarilloSlim
    AmarilloSlim
    Amarillo
    I was curious to how my silver maple was drying. Cut green, c/s/s about 6 months. Reads on average 15%. Same results on the white birch. Honey locust is at 24%
    Seems the wood really drys fast here.
    HoneyFuzz, firecracker_77 and Gark like this.
  2. My IS heats my home
    My IS heats my home
    Albany, NH
    Did you resplit the pieces and get your reading from the inside? or are you just taking readings from the splits as-is?
  3. AmarilloSlim
    AmarilloSlim
    Amarillo
    Resplit. With the grain. Started on some small splits first then grabbed the biggest splits I could yank from the stack.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    You may have some increased drying times there because of the climate. More heat and drier air. Here on the east coast we get more humid air but the sumer breezes and daytime sun do well in helping dry.
    At least you know your in good shape and it's only the beginning of August
  5. AmarilloSlim
    AmarilloSlim
    Amarillo
    Well.... I pulled a huge birch half round from the stack whacked it open and pegged the meter.... I'm sure the fruit woods and softwoods are drying nicely.
    I'm thinking of taking my drier wood and building a holz hausen to open up my single stack row again for new inventory.
    No biggie if my wood needs more dry time. I planned on a stove install this summer and that idea does not look well on paper. Always next year.
  6. My IS heats my home
    My IS heats my home
    Albany, NH
    I was just on craigslist looking at used (and a couple new) woodstoves for sale. All kinds up this way and price ranges from $200-3k.
    I'm doing a little research in order to post my stove for sale shortly.
    What are you looking for?
  7. AmarilloSlim
    AmarilloSlim
    Amarillo
    Englander nc-30
  8. Gark
    Gark
    SW Michigan
    A quick Google of Amarillo says 89 degrees with 47% humidity. Could explain why your splits dry way faster than here. We've had a lot of rains this summer.
  9. stuckinthemuck
    stuckinthemuck
    Amarillo seems to have an advantage over most of us in that it has lower atmospheric pressure, less precipitation, lower humidity, higher average temperature and higher average windspeed.... All good things for drying wood...
    Depending on your setup, the accessories for installation could cost almost as much as the stove.
  10. AmarilloSlim
    AmarilloSlim
    Amarillo
    I've been talking to a general contractor friend of the family. It should be a fairly straight forward install. Getting my homeowners insurance to approve the install might be an adventure though.
    Yes we have some prime drying conditions here. Feel free to drop off some oak for 18 months.
  11. firecracker_77
    firecracker_77
    IL
    But check that load of wood on the way home. May be snake infested.... :bug:
  12. AmarilloSlim
    AmarilloSlim
    Amarillo
    Couple western diamond backs never hurt nobody.
  13. firecracker_77
    firecracker_77
    IL
    Other than the people who suffer an instant heart attack. :eek:
    HoneyFuzz likes this.
  14. AmarilloSlim
    AmarilloSlim
    Amarillo
    I would be more concerned with that oak coming back with some of that dreaded mesquite wood.:whistle:
  15. firecracker_77
    firecracker_77
    IL
    Do you have live oak where you live?
  16. AmarilloSlim
    AmarilloSlim
    Amarillo
    Yes, but I believe it to only be yard birds. The only native oak I know of is scrub oak.:(
  17. My IS heats my home
    My IS heats my home
    Albany, NH
    found you one....
    AmarilloSlim likes this.
  18. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Ive never messed with a moisture meter. Maybe i need one :)
  19. AmarilloSlim
    AmarilloSlim
    Amarillo
    You need a moisture meter and I need another sub 50cc saw!
  20. Paul bunion
    Paul bunion
    You do not need one, they are a nice toy to play with but one isn't essential. I'd say that a scale and sharpie are more effective tools in figuring out how your wood is drying. The only thing a moisture meter can tell you is the % moisture between the tines at the spot you prick, overall for a given piece of wood about the only thing you can learn is the content at different spots with repeated readings. With a little experience your personal heft-o-meter, or your hands, should be able to tell you if a piece of wood is dry. If you really want to know what is going on within your pile, making some observations with a scale over time can tell you how your drying is going and tell you if your wood is as dry as you can possibly make it when it stops losing weight. You can also learn the effect of direct sun/wind and rain if you get some before/after samples on pieces that are kept under different conditions. I'd rather know that my methods for stacking and drying make for the greatest amount of water loss overall, as opposed to the particular content as pricked at an arbitrary spot between 2 or 4 tines within a split.
