Fuel question
Discussion in 'Chainsaws and Power Equipment' started by Ohio dave, Mar 10, 2021.
  1. Ohio dave
    Ohio dave
    Akron, OH
    I buy my small engine gas at a regular gas station and I I always put some Enzyme brand fuel treatment in it. If I start using non-ethanol fuel would I still need the Enzyme?
    amateur cutter, M2theB and mat60 like this.
  2. MikeInMa
    I'm fortunate to be able to get ethanol-free gas. I always add a stabilizer.
  3. Erik B
    Erik B
    Western Wisconsin
    I buy non-E gas for all of my small engines and Stabil goes into all of it.
  4. Road-side Oak
    Road-side Oak
    Southern NJ
    x2... I do the same.
  5. Road-side Oak
    Road-side Oak
    Southern NJ
    Now I just need to figure out an easy way to mix 40:1. My local non-ethanol gas is sold in liters. Have been mixing 50:1 in the past.. anyone have any quick methods? . I suppose next time I fill up I could do some math!:hair:
  6. Erik B
    Erik B
    Western Wisconsin
    I use a bottle of oil that is to be mixed with 2.5 gallons but I only use 2 gallons of gas. That may come out pretty close to 40:1
    Road-side Oak and amateur cutter like this.
  7. Road-side Oak
    Road-side Oak
    Southern NJ
    Mix one 77mL oil with 3.08L of gas? That sound right? Actually pretty easy with metric.:thumbs:
    amateur cutter likes this.
  8. Horkn
    Nope. I've seen zero issues with e10, over 20 years now. I have tried stabil as well as other fuel treatments and none did anything different.
    You need a ratio rite. Makes it easy
  9. Erik B
    Erik B
    Western Wisconsin
    I don't do metric if I don't have to:whistle:
  10. Mag Craft
    I use only non ethanol fuel and never use any stabilizer of any kind. I do not have any problems starting up lawn mowers or weed eaters or chainsaws after sitting a long time.
  11. huskihl
    huskihl
    I fill a 6 gallon can from the e free pump. My oil jugs all have a site window on the side. I dump 4oz of oil (using the window) into a gallon windshield washer jug (32:1) and fill the gallon jug with gas from the 6 gallon can. And then dump that into my 2 gallon saw can.
    40:1 would be 3.2oz per gallon.
    I do it this way because I also fill the tractor and other small engines from the big can. So the big can is always straight gas and little cans are always mixed.
  12. Mag Craft
    Yep I do something similar.
  13. PlumbSplitter
    PlumbSplitter
    Bayville NJ
    I use non E fuel and amsoil Saber oil. Use a ratio rite to mix and that's it. Most quality oils have a stabilizer already in it so it makes adding another stabilizer redundant. Also amsoil recommends 100:1 ratio with the Saber oil for everything. I go a little heavier with 80:1 and so far it's been working great.
  14. Rope
    Rope
    Alaska
    Its just mixed gas don't over think it. Alaska doesn't sell Ethanol laced fuel. I also use Saber and don't care what AMS Oil says, and mix to 32:1 and mix by the 5 gallon can-no issues ever.
  15. unbidden
    unbidden
    RI
    Are there gallon(s) markers on your gas container? No need for metric math.
    amateur cutter and Horkn like this.
  16. eatonpcat
    I think the fumes may be getting to you!!
  17. Nixon
    Nixon
    West Sunbury,Pa .
    25ML per liter will give yo 40-1 . Premix Calculator
  18. huskihl
    huskihl
    Probably
  19. Mag Craft
    Yep I am with you. I have used AMS Oil at 32 to 1. Never had an issue.
    Rope, amateur cutter and Horkn like this.
  20. Rush Battle
    Rush Battle
    WNC
    I run e-free with triple dose marine stabil in my boat. Pull straight gas from it into a 5 gallon can for the mower, splitter, side by side, etc. Then use that gas to mix 1 gallon of premix at a time, 32:1 Red Armor per huskihl . Keeps everything as fresh as I can manage. Need to run the boat and ope more!
