262xp - How far would you drive?
Discussion in 'Chainsaws and Power Equipment' started by Jon1270, Jul 24, 2014.
  1. Jon1270
    Jon1270
    Pittsburgh, PA
    Sure, I'll get some pics together later. I'm out of the house now so it'll be a little while.
    Chvymn99 likes this.
  2. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Mahle usually has a casting number on the base or transfer ports to identify the cylinder. Perhaps if you get a picture Daj will come along and identify it for us. I don't have the resources that Nikko does when it comes to casting numbers!
    clemsonfor likes this.
  3. Jon1270
    Jon1270
    Pittsburgh, PA
    On top of the cylinder, in the ground flat area where the casting riser was removed, there was a pattern of stamped characters. If I remember right it was a tiny 0 over a tiny 1, then a larger B, then a tiny 3 over 3. Is that the sort of thing you're looking for? The other markings are all cast into the flange at the base, rather than stamped.
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    The ones cast into the base or on the exterior of the transfer ports.
  5. Jon1270
    Jon1270
    Pittsburgh, PA
    Gentlemen, I give you the rare and beautiful Mahle 48ZK3.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Makes the find that much better !!! Congrats :)
  7. Jon1270
    Jon1270
    Pittsburgh, PA
    I have no idea whether it's better, but it seems to be a solid saw. I've got it clean enough to see what it needs, and fortunately none of those parts are especially rare or expensive. I'm putting an order together right now. If not for having to get that broken screw out of the case, it would take about 10 minutes to get it all in proper order.
  8. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Jon1270, I just sent a message off to Daj (Saw Troll aka Nikko) to see if I can get the saw dated from the cylinder casting number. Don't be in a big hurry to flip it until we hear back from Daj, you might give up some coin! 175PSI is real close to what the KS P/C did on that saw. so I am interested to see if the saw may be from some sort of transition period, e.g. Mahle copied the KS cylinder exactly! If that is the case the C/P may very well be worth MORE than you paid for the entire saw!
  9. Jon1270
    Jon1270
    Pittsburgh, PA
    Well, that would certainly be nice. Thanks for looking into it!
  10. Jon1270
    Jon1270
    Pittsburgh, PA
    Another clue, albeit unreliable: date codes molded into the plastic sprocket cover / brake assembly suggest those parts were made in February of '93.
  11. Jon1270
    Jon1270
    Pittsburgh, PA
    More date codes on the plastic...
    starter rope spool: Dec. '92
    air filter cover: Nov. '92
    top cover: Feb. '93
  12. HittinSteel
    HittinSteel
    Wooster, Ohio
    Daj? Where did that come from?
    BTW, you should invite him to the site....I dont think we have any members from Norway!
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Daj is his name.
    bryanr2, clemsonfor and HittinSteel like this.
  14. HittinSteel
    HittinSteel
    Wooster, Ohio
    Well Ill be.... I thought it was Nikko
  15. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I feel like we r all about to be corrected on a regular basis now :) lol !
  16. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Nikko is a nickname created from his last name.
  17. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Learn something everday !
  18. Cut4fun
    Cut4fun
    OHIO Redneck
    This other 262 I had had a decomp cylinder. Dont remember the cylinder maker though.
    Guy I know in Ohio that bought my other older 262, has 6 262xp ;).
    HoneyFuzz and clemsonfor like this.
  19. Cut4fun
    Cut4fun
    OHIO Redneck
    I want to say this one didnt have a decomp. But cant remember or confirm from this pic.
    HoneyFuzz likes this.
  20. Cut4fun
    Cut4fun
    OHIO Redneck
    Date tag on the 262xp with trap door in rear handle. Saw above this post.
