MS461 cant pull it to start. Timing off?
Discussion in 'Chainsaws and Power Equipment' started by Dolphus Raymond, Feb 22, 2021.
  1. Dolphus Raymond
    Dolphus Raymond
    Deep South
    I have a Stihl MS461 that I have run maybe 7-8 tanks through and decided yesterday to run it for a minute. Compression break pops up and it is nearly impossible to start. Runs great once it starts but it is a bear to pull. I am guessing that the timing is off. I removed the plug and it turned over fine so it is not locked up. What says the FHC brain trust?
    amateur cutter likes this.
  2. Mag Craft
    When you pull it over is it hard to pull or does it pull back sometimes.
    amateur cutter, Ohio and farmer steve like this.
  3. Dolphus Raymond
    Dolphus Raymond
    Deep South
  4. huskihl
    huskihl
    Turn the ignition switch off and try it
  5. Andyshine77
    Andyshine77
    Cincinnati, OH
    No offense ment, but are you used to running saws of this size and performance? I ask because sometimes guys move up from smaller saws maybe even lower end saws, and they're simply not used to the compression these saws make after a few tanks of fuel has been run through them. Pull her to TDC and pull fast and hard.
    If the saw is running fine in the cut I doubt the flywheel slipped, but anything is possible.
    amateur cutter, Ohio and Mag Craft like this.
  6. The Wood Wolverine
    You could always remove the recoil cover and spark plug, then rotate the flywheel and see if the magnet is even close to the coil at tdc. Not so sure on Stills, but it isn't ridiculous hard to remove a Husky flywheel to check the woodruff key.
    amateur cutter and Ohio like this.
  7. Andyshine77
    Andyshine77
    Cincinnati, OH
    Great advice sir!
  8. Dolphus Raymond
    Dolphus Raymond
    Deep South
    No offense taken, Andy. I run a 362 and a 461 and I usually can pull it even if the compression button is not engaged. This saw maybe has 7-8 hours on it and prior to storage, I put the Stihl brand pre-mix fuel in it. Now, once I got it cranked yesterday, it ran very well.
  9. Dolphus Raymond
    Dolphus Raymond
    Deep South
    As soon as I get home, I will do that. Assuming it turns over like it is supposed to with the switch off, may I assume it is a bad ignition component?
    amateur cutter, Ohio and huskihl like this.
  10. Andyshine77
    Andyshine77
    Cincinnati, OH
    Correct.
  11. Andyshine77
    Andyshine77
    Cincinnati, OH
    Did this happen on the first startup after the saw has been sitting for some time?
  12. huskihl
    huskihl
    Yep that’s where I was headed. Although it could be slightly flooded, where it’s trying to pop but the added fuel makes it so it can’t quite overcome the added compression
    amateur cutter, Ohio and Andyshine77 like this.
  13. Dolphus Raymond
    Dolphus Raymond
    Deep South
    The saw had been sitting for a couple months.
  14. Ron T
    Ron T
    Northeast Ohio....Bowdil
    7-8 tanks. Is the saw still under warranty?
  15. Andyshine77
    Andyshine77
    Cincinnati, OH
    Did you add any extra lube to the top end before putting her to bead?
  16. Dolphus Raymond
    Dolphus Raymond
    Deep South
    Problem solved I think. I left the switch off and it pulled like it was supposed to. Then i choked, pushed the de-comp and it pulled off perfectly. Then, after running it for a minute, I attempted to start it again. Same problem. I'm guessing I need a new ignition module?
    Thanks everyone for the help.
