Project Farm compares chainsaw sharpeners
Discussion in 'Chainsaws and Power Equipment' started by TurboDiesel, Feb 21, 2021.
  1. TurboDiesel
    Another great vid by Project Farm.
    Stlshrk, OldJack, ReelFaster and 6 others like this.
  2. Ward Hoarder
    Ward Hoarder
    West Virginia
    I've watched several of his videos. He seems to be fair and unbiased.
    Stlshrk, OldJack, XXL and 3 others like this.
  3. The Wood Wolverine
    While I like his testing methodology, his idea of sharp and mine are definitely different.
    Then there’s this:
    :zip:
    Stlshrk, Slocum, XXL and 4 others like this.
  4. Warner
    Why not speak up? What’ wrong with what he says? Trying to learn here.
    Stlshrk, Slocum, XXL and 2 others like this.
  5. The Wood Wolverine
    Speak up, me? I like his vids, but my personal preference is different. Nothing wrong per-say, I just do it different. He puts a lot of time and effort to get those results. :yes:
    Those shimmers/shiney spots along the edge of the cutter are light reflection. To me that indicates it's not quite sharp yet.
    Stlshrk, Slocum, XXL and 6 others like this.
  6. Warner
    I need to take time to learn more about sharpening!
  7. JimBear
    JimBear
    I want to like this post again.
    Stlshrk, XXL and amateur cutter like this.
  8. JimBear
    JimBear
    I applaud his effort & his methodology also & the time he took to do so. BUT everyone is a critic... That being said that toof ain’t sharp, I would be hanging that one on the needs sharpened peg. At least one toof was burned from hacking too much-too fast off with a wheel grinder. One mans sharp chain isn’t every mans sharpened chain.
    He also didn’t go into detail on how he maximized sharpness on the 2nd round so folks that are trying to learn can learn.
    Everyone develops their own technique good/bad/ugly but for safety sake & best results a solid-stabil mounted bar in some type of vise ( bench vise/log vise) or chain vise are best for the least amount of movement & best results, especially for folks just starting out. Alot folks are heavy handed when they start out sharpening. I am speaking from experience.
  9. amateur cutter
    I've spent a lot of time learning to sharpen as well. I bought a really nice grinder, read, watched, learned & promptly destroyed a few chains. I am modestly proficient with a file & pretty good with a grinder. It takes a very light touch with a grinder to make a truly sharp chain & that comes with practice. Now that I've gotten decent with round ground chain, these guys have got me just about shamed into going "square". If you look closely at some of Jason's pics of cutters he's sharpened you'll see a mirror finish on all the angles. Those chains will cut smooth & fast, they'll be 10-20% faster than my best round grind. I've screwed around with angles, raker height, & chain type long enough to know what I like. Best teacher is practice & patience. Find what works for you & make firewood.
    Stlshrk, Slocum, fishingpol and 4 others like this.
  10. Chud
    Chud
    What don’t you like about what he is doing to the depth gauge? Removing too much? Squaring it? The Oregon tool?
  11. Nixon
    Nixon
    West Sunbury,Pa .
    I’ll hazard a guess . He’s just doing the standard “ .025 depth gauge setting fits all “ ,file job .
    Using a progressive gauge will give better results . Especially as the cutter gets filed back a bit . I post this from time to time ,as it is helpful .
    http://gepkolcsonzo.eu/wp-content/uploads/2012/01/complete-book.pdf
    This will explain it a lot better than I can . Lots of other good stuff in there as well
  12. The Wood Wolverine
    Nixon summed it up. If you're interested enough to learn how the chain does its cutting, read that file he shared. It's very informative, especially the part about the depth gauges. Progressive style is best in my eyes.
    Stlshrk, OldJack, huskihl and 2 others like this.
  13. ReelFaster
    ReelFaster
    S.Jersey
    Great video, I enjoy his content, thanks for sharing!
    I only have a few years experience running saws but I picked up the Stihl 2 in 1 file sharpener and its by far the best I've used. So simple to use and the results are top notch as you can see by his comparisons.
    Stlshrk, amateur cutter and JimBear like this.
  14. Warner
    Thanks for the info!
  15. Chud
    Chud
    Just curious about the why. I mostly use the progressive gauge, but in the field I may run a file across flat.
    In my opinion a chain is in 3 categories. It’s cutting good, could be better, but it can finish the job, or I’m not using it.
    I like using saws that I’ve sharpened, because I know exactly how it’s going to cut, but I’m not going to sharpen all the saws all the time at work. Optimum is not always possible in a work environment.
  16. amateur cutter
    Agreed, Saturday I had a split Oak limb to buck, hit something & trashed the chain, grabbed another saw & hit something else. Got annoyed & threw on a stumping chain. Was it great, no, but good enough. Finished the day with it, then sharpened the good chains. Sometimes you just gotta get the job done.
