Pellet Count for 2020/2021 Season
Discussion in 'The Pellet Bag' started by bogieb, Nov 1, 2020.
  1. CleanFire
    CleanFire
    94 bags of Satisfaction pellets as of Jan 31,
    220 gals. (approx.) of diesel: with Betsy's early work hrs. / schedule, and my working from home.. we've been keeping the temps. in the house a little warmer this season.
    Tiny Francesca stove is still plugging along, but showing it's age. ... Might be time for a replacement stove, at the end of this season.
    bogieb and jtakeman like this.
  2. Rich250
    Rich250
    Berks County PA.
    Just finished off 2nd ton of 50/50 mix of hardwoods and Virginia Goldens now on to the AWF white pines
    CleanFire, bogieb and will711 like this.
  3. Tullytown
    Tullytown
    North of Phila Eagles.
    should have said 3 tons SINCE mid October..
    CleanFire and bogieb like this.
  4. bogieb
    Figured that was what you meant.
    CleanFire and Tullytown like this.
  5. Mr Brick
    Mr Brick
    Nh
    Just polished off my third ton of green supremes, starting in on wood and sons. I like my main room at 80, and the pellet stove is all I'm using for heat, so I don't think that's awful. Could do better, if this blasted house had any kind of insulation.
    CleanFire, bogieb and jtakeman like this.
  6. Tullytown
    Tullytown
    Mine has barely any insulation so its pretty much 4 tons a season. Have oil fired furnace for heat but only use for hot water or if temps go into single digits so pipes dont freeze.
  7. bogieb
    Filled th stoves for the day and have used 49 bags for the month of February (most I've used for a month this year). So far this heating season I've used a total 187 bags.
    Until this month I was on track to use the least amount of pellets since I started burning. That got shot down this month, but still in the running for 2nd lowest.
    CleanFire and jtakeman like this.
  8. Tullytown
    Tullytown
    Right back atcha.....was doing excepetionally good till feb smacked my stash like a wrong way door!!
  9. jtakeman
    Feb = 33
    YTD = 112
  10. ivanhoe
    ivanhoe
    Northern Ontario
    47 for Feb and 194 YTD with corn/oil.
    bogieb, CleanFire and jtakeman like this.
  11. bogieb
    34 bags used for March, with 220 used for the season so far.
    The first half of March was cold, cloudy and windy so I thought for sure I would use as much as usual (right around a ton; 44-52 bags is the range for the last four years). But have had lots of sun and some really nice days the last 2 weeks so no I am just barely below my lowest use winter.
    April is the month that is unpredictable - I've used as little as 7 bags and as much as 28 in previous years with the average being 21.
    ivanhoe, CleanFire and jtakeman like this.
  12. Tullytown
    Tullytown
    Just hit the 200 mark yesterday..
  13. Skier76
    Skier76
    CT and SoVT
    Ordered three tons. Went through about 2.5+ thus far. Oddly, seems I went through less despite working from home for the entire heating season.
    ivanhoe, CleanFire and bogieb like this.
  14. jtakeman
    22 bags used for March, with 134 used for the season so far.
  15. Pete Zahria
    Pete Zahria
    New Hampster
    Don't forget.
    We had the second warmest March on record.......
    Dan
    Lousyweather, ivanhoe and CleanFire like this.
  16. CleanFire
    CleanFire
    18 bags in Feb., 16 bags in March = 128 as of 3/31/21,
    85 gals. in Feb., 14 gals. in March = 319 gals. for Dino-Burner (off-road diesel) so far this season.
  17. ivanhoe
    ivanhoe
    Northern Ontario
    38.5 bags & remainder of corn for March, 232.5 YTD
    bogieb and CleanFire like this.
  18. Luneyburg
    Luneyburg
    Hills of Central Mass
    Too Many as usual 6 Skids of LaCrete and three tons of MWP and still burning ....
    Finished the 2+ year job from hell and have done 4 since then so not much work on the house . Not what I would consider a good year most importantly lost my Mother to Cancer and to be Blunt it was horrible but the only salvation is that she suffers no more.
    Miss my friends here and hope to be back more often but still very busy taking care of my Father whom lost his life long partner along with work . Bought a few pellet grills and fly my drone when possible to chill then and making videos .
    Hope all are well after checking around see that JT is in a fight and JT I wish you well and will add you to our prayers .
    CleanFire, ivanhoe, slvrblkk and 2 others like this.
  19. bogieb
    Sorry for the loss of your mother and consequently the added stress of taking care of your father.
  20. Luneyburg
    Luneyburg
    Thank You bogieb
    CleanFire, ivanhoe and bogieb like this.
