550xp
Discussion in 'Chainsaws and Power Equipment' started by CNE deer, Feb 14, 2021.
  1. CNE deer
    CNE deer
    ohio
    I was at Rual King and they had a 550xp looked new but was on the AS IS table for 475, didn't say what was wrong with it but seemed to have compression. Is it a deal or pass?
    M2theB and Sandhillbilly like this.
  2. System
    System
    Western MA
    Is it the newer Mark II version? I wonder why they are calling it "as is?" Customer return? Whatever the case, it seems to be priced too high even without the "as is" disclaimer.
  3. The Wood Wolverine
    As is is tough. How good are you at working on your own stuff and do you have a friend or very good dealer with the software to plug in to the newer tech? I'd say that's pretty high if there's an issue with it.
    Husky Man, M2theB and Sandhillbilly like this.
  4. CNE deer
    CNE deer
    ohio
    I think it was a customer return .
    M2theB likes this.
  5. CNE deer
    CNE deer
    ohio
    Chainsaws have a computer now ? WOW I didn't know that
  6. System
    System
    Western MA
    Even so, that price is too high.
    Yes, some of the Husky's have AutoTune (computer controlled carb). The first gen of the 550 had it. The Mark II doesn't appear to have it or at least it's not mention in the specs on their website...
  7. The Wood Wolverine
    5 series Husky's have autotune. You'll need to plug in to diag fuel delivery issues.
    M2theB, Sandhillbilly and huskihl like this.
  8. huskihl
    huskihl
    I’d pass. I’ve seen new with warranty shipped for $460
  9. Chud
    Chud
    From what I’ve seen on the web, the 1st gen 550 has a design flaw where too much heat is transferred from cylinder to carb causing hot starting issues. There is not a heat shield, or an inadequate shield between cylinder and carb.
    Husky Man, M2theB and CNE deer like this.
  10. Farmchuck
    Farmchuck
    Nepa
    At that price I agree with the others I’d leave it on the shelf.
  11. M2theB
    M2theB
    Central Massachusetts
    As is might mean it has the infamous off idle bog. Can be solved with a new AT-12 carb as long as it’s in the right series with the coil. That’s $120 DIY fix if that’s the case.
  12. The Wood Wolverine
    Just to give you an idea of their value around me:
    Brand new:
    CNE deer, M2theB and Husky Man like this.
