Pro generator
Discussion in 'Chainsaws and Power Equipment' started by old iron, Feb 13, 2021.
  1. old iron
    old iron
    sw va
    ABB60FE9-8B07-4049-8796-DBFCD207B83B.jpeg 41503C07-11FA-4C26-93F3-F837225C2C74.jpeg 68DF728F-C207-43F3-AFF7-D2439C7E0DB3.jpeg D3FF201D-EE92-4E30-8B40-46467E920270.jpeg 297A5E1D-F0DF-403E-9E20-48843B40DA07.jpeg 23ACA5F0-2E7C-4587-9376-2E9046E65E83.jpeg 6AF0C520-4E08-4243-93FF-E097C83F6BEB.jpeg CF9B9A58-61FE-45FC-A2E4-0DAE0B93BECF.jpeg Last week we had a bad windstorm I live near I 77, it blew three eighteen wheelers over three miles from my house, I bought this gererator several years ago but didn’t like running my tractor twenty three hundred rpm to generate power so I found this Hatz two cylinder diesel around ten years ago with thoughts of it running my gen,so after the wind and being without power for thirty Hoyt I thought it was time to convythe generator , when I removed the gearbox off gen I found the armature was supported by bearing in gearbox so I had to turn armature and bore housing for bearing then built a trailer for it, I’m getting close to finishing
  2. old iron
    old iron
    sw va
    Auto spell
    Ron T, Screwloose, metalcuttr and 2 others like this.
  3. amateur cutter
    That'll be a really nice set up when finished. Well worth the effort I think. Nice work.
  4. Spencer
    Spencer
    Cool project. THanks for sharing.
  5. old iron
    old iron
    sw va
    Thanks fellows, finished it up today would like to take it back apart and paint sometime, but probably need to cut more wood 0606FCBC-7B79-4F7F-8B3B-BA8B9CBD00AC.jpeg
  6. Screwloose
    Looks nice but that engine sure seems small for the generator especially if its 1800 rpm.
  7. bushpilot
    bushpilot
    Eastern Washington
    Hmm, need more pics of the goodies and projects in the shop...
    amateur cutter likes this.
  8. eatonpcat
    Nice job!!
    amateur cutter and Screwloose like this.
  9. old iron
    old iron
    sw va
    Bushpillot have a couple model t Ford’s and a 31 model A Tudor just started working on a 32 roadster I’ve had 10-12 years and starting back together
  10. Screwloose
    That's a sweet looking machine you have there. It looks well cared for.
    amateur cutter and eatonpcat like this.
  11. old iron
    old iron
    sw va
    1915, the seat machine belongs to a friend,I have a kwik way but his works better on the T and A blocks
