'21' on the chain question...
Discussion in 'Chainsaws and Power Equipment' started by OldColo, Feb 5, 2021.
  1. huskihl
    huskihl
    amateur cutter and Chud like this.
  2. OldColo
    OldColo
    Colorado
    Holy cow. Came back and a virtual encyclopedia of replies.
    To answer one... there is no other identifying stamp on the chain other than '21'. As said, it is an offbrand no name knockoff. I recall looking it up like 4 years ago based on the info on the box, long gone, and it appears to have been made for England, but marketed for 5 minutes in the US. Nothing on the saw itself. It is definitely underpowered but danged if it doesn't cut like a sum-b¡tch. Have ground through many silver maple rounds, some 30" or more.
    Anyway, I am amazed at all the responses. I will see about photographing the chain itself, but there is little to glean. I tried to sharpen it with a chain saw chain grinder that I have used for years with other chains and I mangled the sh!t out of it. My fault. I am way better than that. But on familiar. I can make my skip chains for the Stihls pristine. This one, goes to show how being off just a little can throw a wrench in the werks.
    Will re-review all the posts and if there is anything more to glean from the chain, will post a pic. I don't think so.
    Fantastic thread, this.
    amateur cutter and farmer steve like this.
  3. OldColo
    OldColo
    Colorado
    I learned more reading this thread than I have like pretty much ever... and I have been doing this for years.
  4. huskihl
    huskihl
    Need...
    chain....
    pics.......
  5. Chud
    Chud
  6. buZZsaw BRAD
    Hang around for a while and be amazed at the stuff you'll learn. I certainly have! :sherlock:
  7. Farmchuck
    Farmchuck
    Nepa
    huskihl is correct. If it is in fact Oregon brand chain it is .325 .58 gauge. That particular chain calls for a 3/16” file.
  8. OldColo
    OldColo
    Colorado
    Pic of chain. Now that I have looked at it... Zhuang chain. Stamped onto the links. And '21'. It is a 24" inch chain, but here is a link that drilled down into more info. As have said, I have been amazed at how durable the two chains that came with the saw have been. And the saw. Found a link that identifies the saw too.
    Here is the saw that came with the two 24" chains.
    The (SURPRISINGLY GOOD) TIMBERPRO 62cc 20 inch gas chainsaw
    Purchased 3+ years ago. Cheap-o. But keeps running. Used to cut thru large rounds.
    Chain pic
    Rush Battle likes this.
  9. unbidden
    unbidden
    RI
    I'm late to the party here. :binoculars:
    Go over the bar and sprocket with a magnifying glass to see if the parts are stamped with the pitch.
  10. MasterMech
    A good while back, we thought it would be great fun to do a Chinese chainsaw build-off for an FHC G2G in PA. I bought a no name 52cc saw, which to the best of my knowledge, was a copy of a Zenoah design. The thing looked and felt like a Fisher-Price. But it ran like a Top-Fuel dragster. It ended up being an air-leak basket case, as many of the Chinese saws did, but when running right, it was ridiculously strong for 52cc.
    farmer steve and huskihl like this.
  11. huskihl
    huskihl
    In earlier posts, we assumed that because it had a 21 on it that it was an Oregon chain. It’s obviously not, so that info should be thrown out. But still, pitch usually determines the file size. Measure the distance between any 3 rivets and divide by 2. Or if all you have is a tape measure, measure the distance between say.... 11 rivets and divide by 10. If your answer is around .325, you need a 3/16 file
    farmer steve and Farmchuck like this.
  12. OldColo
    OldColo
    Colorado
    Not that anyone was waiting by the fire for me to respond. But... ended up with a Pferd 3/16th and yes, it appears to be the correct fit. Will be able to give this a go in a couple of days. Going to be below 0 here in Colorado front range for a couple of days... Woodstock wood stove humming along...
    Farmchuck, Chud and farmer steve like this.
  13. Farmchuck
    Farmchuck
    Nepa
    Glad to hear you figured it out & it’s working. Keep that stove a blazing!!!!!
