'21' on the chain question...
Discussion in 'Chainsaws and Power Equipment' started by OldColo, Feb 5, 2021.
  1. OldColo
    OldColo
    Colorado
    Sophomoric question.. I purchased a cheap-o unbranded saw with a 24" bar that has ended up being awesome. Paid like $110 4 years ago and danged if it has been underpowered but cuts like a champ. Came with 2 24" chains.
    I am trying to determine what file size I need to sharpen the chains. The cutters have a '21' on them. Can anyone tell me what they are, what file diameter I need to get? I might just get a pferd sharpener, but not sure what to get.
    Have used this saw to grind thru some silver maple rounds over the years and was amazed at how sharp the chains remained. Not used heavily, but it does the job. For the record, I have among other things some Stihls that are my go-tos. Still, I never thought this off brand thing would work very long but it keeps humming. Takes a little longer to get thru a large round, but hey. My standard wood is pinon and lodgepole pine which the Stihls eat for breakfast.
    tx
  2. buzz-saw
    buzz-saw
    Ct.
    [​IMG][​IMG]
    Figure out the pitch and that will determine what file you need.
    The chart on the right shows "#21" , I'm guessing it is a 3/8 pitch chain based on that = 3/16 file if that's the case.
  3. The Wood Wolverine
    Most of the 3/8th pitch that I’m aware of is 7/32, unless you have some low-pro. Is there a pic or brand name on said chain?
  4. buZZsaw BRAD
    Its either 3/16 or 7/32. Bring the chain to an OPE dealer and see which size fits the curve of the cutter. They usually sell loose files.
  5. Lastmohecken
    Lastmohecken
    Arkansas
    There is also 13/64" files, between 3/16 and 7/32"
    I think a lot of chains and dealers recommend 13/64" for 3/8" pitch chain, and the 2 in one Stihl sharpener has 13/64" round files in it, I believe, for 3/8" x 50 chain. And .325 has 5/32" round files in it. Personally, I go to 3/16" on .325 chain and 7/32 on 3/8" chain. On the first sharpening you will end up opening up the hooks/gullet a little bit more. It' easy to see this on the chain, by just laying a file on the tooth of a brand new chain.
    amateur cutter, Smaug and Horkn like this.
  6. buzz-saw
    buzz-saw
    Ct.
    I have Stihl kits for the PMM chains like on the MS170 , .325 and 3/8.
    Now I am curious and will have to look later when I get home as to what they actually are.
    amateur cutter likes this.
  7. MasterMech
    3/16" File is typical for .325" chain, not 3/8" (.375"). 21 stamped on the cutters would suggest it's Oregon .325" pitch, .058" gauge chain.
  8. buZZsaw BRAD
    Same here. I buy files by the dozen. Now with the little saws i need 5/32.
    I guess CAD has its drawbacks!:picard::rofl: :lol:
  9. huskihl
    huskihl
    3/8 lo pro = 5/32
    .325 = 3/16
    3/8 stihl = 13/64 (but most use 7/32)
    3/8 Oregon and .404 = 7/32
  10. huskihl
    huskihl
    I believe the 21 is an Oregon .325 .058 ga chain
  11. buZZsaw BRAD
    would that be the same as Stihl picco 3/8"P chain?
  12. Erik B
    Erik B
    Western Wisconsin
    What file is needed for the standard chain that comes on a ms170?
    amateur cutter and buZZsaw BRAD like this.
  13. buZZsaw BRAD
    I believe its 5/32" which is what i used on mine.
    amateur cutter and Erik B like this.
  14. Erik B
    Erik B
    Western Wisconsin
    Thanks buZZsaw BRAD
  15. buZZsaw BRAD
  16. huskihl
    huskihl
    Yes
  17. Chud
    Chud
    Are you aware of anyone making a file smaller than 5/32 for the Stihl 1/4” chain?
  18. buZZsaw BRAD
    My circa 1973 020 rear handle came with a file guide with an 1/8" file. File was dull as hell and i used the 5/32 to sharpen the chain. Its some weird chain size too.
    amateur cutter and Chud like this.
  19. Chud
    Chud
    I also want 1/4” Stihl chain that doesn’t have double drags/rakers/depth gauge/guides
  20. Lastmohecken
    Lastmohecken
    Arkansas
    Yep, that's one reason I switched out my .325 chain and bar for a 3/8 x .050 on my 261. The .325 may actually be the better choice for that saw, but I wanted to stay with 3/8 pitch chain.
