Garage addition
Discussion in 'The DIY Room' started by rusty ranger 44, Jan 30, 2021.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    Questions if you were thinking of adding another bay to your garage what would you like to have. Such as concrete floor with drain. Garage doors on each end. what type on lighting. windows two post car lift prepiped air lines Dedicated area for welding,what type of covering on walls, ceiling. building to match the existing structure or a lean to. Let me hear your thoughts
    M2theB and Camber like this.
  2. Softwood
    Softwood
    Central WI
    I'd add two bays..:D
    MasterMech and M2theB like this.
  3. rusty ranger 44
    rusty ranger 44
    south central Pa
    I hear ya The neighbor may get a little upset if we did.
    Softwood likes this.
  4. stuckinthemuck
    stuckinthemuck
    Radiant floor heat...
    LongShot, PA Mountain Man and Camber like this.
  5. Camber
    Camber
    Montana
    sound proofed and optical scanner door lock
  6. yooperdave
    I had a lean too addition added to the garage a couple years after I had the garage built. I was going to have it built 8' wide the entire length of the garage but thought 9' would be better and should have had it built 10' wide. I can back vehicles into the lean to but it is a little too "snug" for a "mature built" man to get out of the vehicle. I'll explain why.
    First year the lean to was built, I left it open with gravel floor and used it for overflow outside storage that would be protected from weather. But, snow blew in from open areas a bit more than I had anticipated. Next year, I bought some fence panels and attached them to the support posts of the lean to which closed if off from the weather...but.......I can no longer open the vehicle door wide enough for me get out comfortably. You see, the first year, I would position the vehicle so it's door would swing open between the lean to posts...no problem then. Once the fence panel walls were put up, problem. 10' would have helped out a lot.
    Ended up running wiring and lights out there under cover of the lean to also.
    M2theB likes this.
  7. sirbuildalot
    sirbuildalot
    Mass
    #1 rule of building an outbuilding
    Build it bigger than you think you need
  8. PA Mountain Man
    PA Mountain Man
    Lisburn, PA
    Bar and beer fridge!:coldone::coldone::coldone:
    M2theB and Canadian border VT like this.
  9. Canadian border VT
    Yes I did. See pic 37E7AB4E-7FD2-4CA8-A23A-2594EE814C75.jpeg was a 2 1/2 and enlarged to a 3 1/2.. there was a lean to where new bay was and did not need a permit if under 100 square feet a year. Which only was important as I was in set back. Addition was 24 x 16.
    build it BIGGER. a bay should be 28 by 24 minimum
    A lift requires height definitely drive in and out
    2 man doors for fresh air
    Heat. Enough room for a bench and 2 work on vehicle/tractors mowers inside.
    eatonpcat, M2theB and clay shooter like this.
