  1. Gasifier
    10 here. Just put some large Pine splits in.
  2. Backwoods Savage
    24 when I sacked out last night. 31 when I got up this morning.
    Looks like we may see some sunshine for a change and very welcome.
  3. thewoodlands
    thewoodlands
    We went down to -5 earlier this morning but when I finally got up we had 13 degrees.
    We have some Yellow Birch and Ash going in the wood stove.
  4. Rope
    Rope
    Alaska
    8* and 72* with spruce doing its thing. It nice to be above 0* for a change.
  5. yooperdave
    Warmed up but still a breeze out today so far. Nice and mild temp of 27 and light snow. Looks like I'll have to put the shovel down once more.
  6. moresnow
    moresnow
    30f now and supposedly going a few degrees in the correct direction yet:thumbs:
    Currently melting down some coals from last nights 9pm load.
    With the warm spell today I am going to shut er down and apply the Sooteater late afternoon for a check. Started burning in Oct. so it should be interesting to see what lurks in da pipe! Probably the longest stretch I've let a cleaning go. I can usually tell if my bypass mechanism is starting to grind and I hear crunchy creo falling in the pipe if I tap/whack it. No such issues this year with 3 year seasoned fuel. Good stuff.
  7. yooperdave
    Temps are in the teens and falling; wind is making it miserable outside once again. Still have the light snowfall.
  8. clay shooter
    clay shooter
    ENGLAND
    the 2 days of rain are gone,back to normal now dry,
  9. Biddleman
    Biddleman
    River Hills of Pennsylvania
    43 right now, but it was a very long day at work and want a nice hot fire to sit by and relax.
    Horkn, clay shooter, Gasifier and 2 others like this.
  10. Buck55
    Buck55
    Rochester, NY
    Been in the 30's here, dipping into the 20's at night. Winter has been a dud thus far. I've been burning mostly red oak and ash after starting the fire with cherry. I am feeling the need to get out this weekend for some cutting and hauling therapy.
  11. yooperdave
    Sitting at 10 now with wind but the snow has stopped. Shoveled everything 1/2 hour ago. Not much snow but enough to not want to walk or drive over it. Anyway, it wasn't bad outside, just wasn't your best "happy place" :D
  12. moresnow
    moresnow
    27F and 71F with a fresh load of mixed 2 hours ago. Swept the system and collected about 3 cups of light dusty junk this afternoon. Better part of 4 month's burning. No complaints whatsoever. Running the forced air heat for a couple hours sucked:)
  13. thewoodlands
    thewoodlands
    We have a temp of just over 30 tonight, I have the pellet stove providing the heat tonight.
  14. yooperdave
    Sending some "winterlike" temps your way. You're welcome!
  15. thewoodlands
    thewoodlands
    Thank you Accu yooperdave . We canceled or pizza run into Sergi's in Potsdam NY tomorrow but the wife will cook chili. :zip:
  16. thewoodlands
    thewoodlands
    Snow showers with embedded snow squalls are expected on Friday across the North Country... Snow showers with embedded snow squalls will develop across northern New York during the mid morning hours and spread into Vermont by early to mid afternoon, as an arctic cold front moves across the region. Visibilities will drop below 1/2 mile and a quick 1 to 3 inches of snow is possible in the heavier activity. Be prepared for rapidly changing conditions, which may cause very hazardous travel with poor visibility and quickly snow covered roads. Slow down and allow extra time when traveling.
  17. thewoodlands
    thewoodlands
  18. Backwoods Savage
    Enjoyed the relative warmth yesterday. Had sun all morning. Wind picked up. Got more wood on porch, ran tractor enough to get good and warmed up and also put more fuel in it. Even got the golf cart out and took some things to a neighbor.
    While on tractor I saw several deer. One was about 15 yards from me but showed no sign of fear. I shut the tractor off and enjoyed talking to it. Later I saw a bunch of them. Sweet!
  19. Rope
    Rope
    Alaska
    Woke up to -8* and 72* spruce doing the deed. Saw between -11* and +12* on this mornings commute.
  20. Gasifier
    22ish. Just about to put some Pine in the Wood Gun.
