Charcoal vs Gas
Discussion in 'The Smokehouse' started by Mr A, Jul 20, 2014.
  1. Mr A
    Mr A
    I seem to remember years ago I was prejudiced against gas grilling. Somewhere along the line, I became a gas griller. Convenience I guess. I recently picked up a Weber kettle grill at a swap meet. It took a bit of relearning, and a few rib racks and chicken parts later, I declare charcoal to be superior to gas grilling. Also trying out burning some oak, almond and mulberry in the Weber as heat fuel. Still getting the bugs worked out to control temps. I use the indirect heat method, wall off a pile of charcoal with tinfoil, a few wood chunks on top, awesome barbecue. That's barbecue, not grilling.
    Pallet Pete, basod, gbreda and 2 others like this.
  2. DaveGunter
    DaveGunter
    Looks good to me. I use both, depends on what I'm after and how much time I've got. Hectic evening weekday meal that just needs to be cooked than gas it is, taking my time and enjoying the process, usually on the weekend then charcoal/wood it is, no contest.
  3. Certified106
    Certified106
    In The Hills
    I can get my Chargriller Kamado style from unlit to 350 and ready to go in about 15 minutes. I made the switch from gas to natural lump awhile ago and have never looked back. I can't even imagine grilling a steak on a gas grill now. There is also a HUGE difference between charcoal and natural lump. All that being said I have a friend who doesn't like the taste of anything grilled unless is is off of a gasser so it's probably just personal preference.
    gbreda and Chvymn99 like this.
  4. Chvymn99
    I think there is a place for both. I'd like to have a gas grill for weekday nights. But I've got my charcoal grill that I keep rolling...cause I love the smoke flavor that is induced in the food.
  5. savemoney
    I would prefer hot coals from a wood fire. Of course that requires a lot of time and preplanning, but for anyone who has ever used it, it is by far the best. There is an odor to briquettes that stinks if they are lighted with starting fluid.
    Grizzly Adam likes this.
  6. Daryl
    Daryl
    In a hurry - charcoal.
    Have time - wood.
    Reminds me of my ex so I have no interest - gas.
    thistle, swags, Jack Straw and 5 others like this.
  7. Certified106
    Certified106
    In The Hills
    So your ex was gassy :rofl: :lol:
    splitoak, thistle, swags and 2 others like this.
  8. gbreda
    gbreda
    NH
    X2 !! 15 minutes at most for lump charcoal a little longer if I want 700 deg for a steak sear-once it catches it can go nuclear real quick with both vents wide open.
    No chemical smell or tastes from briquettes or lighter fluid. I gave away my gas grill 2 years ago.
    splitoak likes this.
  9. gbreda
    gbreda
    NH
  10. Mr A
    Mr A
    You don't need lighter fluid to start briquettes. I have a chimney starter. Just a piece of paper gets gets a good stack of charcoal going in about 20 minutes. Using lighter fluid is so common, it has given charcoal a bad rap.
    thistle, basod, gbreda and 2 others like this.
  11. cory@owen
    cory@owen
    Weber starter cubes are my favorite way to light charcoal. They are cheap too.
    gbreda likes this.
  12. Daryl
    Daryl
    (I knew that was coming ;))
  13. grassguerilla
    grassguerilla
    Morse Mill Mo. (Just south of St Louis.)
    Gas grills are for when its raining or snowing and you just don't want to cook indoors or futz about too much out. That, and cooking hot dogs for the kids. Otherwise its lump or chunks on the Weber.
  14. DaveGunter
    DaveGunter
    Anyone ever made your own charcoal on a Weber? Seems like you could just load it up with chunks, get it burning good and then shut it down tight?
  15. 343amc
    343amc
    Northeast Lower Michigan
    I've thought about trying that more than once. I prefer lump charcoal over briquettes, and I could probably make a bunch of lump charcoal with smaller pieces of maple I have in the stacks. I watched a show on tv a few years ago about how the Jack Daniels distillery makes their charcoal. If I remember right, they get a good fire going, then spray water on it when it's burned enough. I'm sure there is some rule of thumb to follow about when to quench the fire.
    I use both gas and charcoal. Burgers, bratwurst, hot dogs and sausage are almost always done on the gas grill. Everything else is either done on charcoal or the pellet smoker.
    savemoney likes this.
  16. Grizzly Adam
    Grizzly Adam Guest
    I'm with Savemoney on this one-- wood all the way. Split it small, season a few months and use a chimney starter. I had steaks on the grill tonight in under 25 minutes.
    thistle, Woodwidow and basod like this.
  17. cory@owen
    cory@owen
  18. mattjm1017
    mattjm1017
    @Grizzly Adam are those steaks cooking right on the wood?:confused:
  19. Grizzly Adam
    Grizzly Adam Guest
    Yep, right on wood coals. They were great.
    thistle and mattjm1017 like this.
  20. nate
    nate Banned
    Palmer, AK
    Taste the meat, not the heat! 20 mins is entirely too long. With my propane grill I already ate and am picking my teeth saying damm that was good in 20 mins.
