Best wood for a splitting round
Discussion in 'The Wood Pile' started by Yawner, Jan 6, 2021.
  1. Sinngetreu
    Sinngetreu
    North Central Iowa
    No real special method. I just drizzle it on with a can or so. I just try not to pour too much at one time so it doesn't get all over everything. Let it soak in and then go for a second coat if need be. It keeps soaking in, so I reapply when ever it seems like it could need it. I've used a brush on other things before too and that works ok.
    Yawner likes this.
  2. Jon_E
    Jon_E
    Southwestern Vermont
    White pine, about 30" diameter crotch piece. Pine heartwood is surprisingly rot-resistant; I have some large pine logs that have been sitting on the ground for 15+/- years now, the sapwood is all punky and falling apart but the heart is still really solid.
    Midwinter, Chazsbetterhalf and Yawner like this.
  3. Andimus Prime
    Andimus Prime
    NW NC
    This works well for me too. Before the splitter, I had a ~6” thick round from a holly tree (hollywood?) that worked well. That wood was very dense and hard to split. I’ve never dealt with elm but heard plenty about how tough it is to split. The little bit of black gum I’ve cut was too small to split.
    Chazsbetterhalf likes this.
  4. Midwinter
    Same here, they are plentiful, just swap them out as needed
