Loading trailer/truck with heavy pieces?
Discussion in 'Chainsaws and Power Equipment' started by Lennyzx11, Jan 6, 2021.
  1. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    Looking to the group to find out your ways of loading scrounged wood that’s a bit heavy or awkward.
    I had scored a pile of about 4 ft long and 12-18” diameter ash that was hard on me to load by myself.
    They didn’t want to let me cut it up on their property. But I could get the trailer up next to the pile.
    I have a dump trailer and a winch on a receiver mount that I use to drag logs in the back. But that doesn’t work very effectively for the little logs before running winch batteries dead for a big score.
    Some thoughts are
    Bunch up some at a time and run the winch with bigger loads. This is my best idea so far.
    Use a dolly and roll it close to the back and “flip” them in.
    Quit cryin and keep dragging.
    This was prob a cord of ash so it was worth working for.
    How are you professional scroungers snagging big loads?
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Make/get a set of long jumper cables to run from your truck to the trailer batteries and charge em as you load.
  3. Warner
    I was thinking the trailer batteries should be charged by the truck as well.
  4. amateur cutter
    Put the trailer ramps out & roll them up? Save the winch for the big ones.
  5. Yawner
    Yawner
    Louisiana
    I roll them up the ramp on my trailer and I also use a heavy duty dolly that has a lip platform that can be extended down to make the carrying platform larger to accept bigger rounds.
    Backwoods Savage and mat60 like this.
  6. rdust
    rdust
    SE, Michigan
    Use a dolly and ramps for my trailer but it’s not tall like a dump trailer. It’s an equipment type trailer with a dovetail so pretty low.
    A steel conveyor with rollers might work good for your situation.
  7. billb3
    Going to be doing enough of this to yield ROI on a gas engine capstan winch ?
    Electric Winch batteries, overloads, short working times can be a PITA.
  8. Lennyzx11
    Lennyzx11
    Yeah, I’ve got the wants for a gas engine hydraulic unit. But whew! They are high. I don’t have enough of these situations or need that much wood so can’t justify that.
    Been drooling over forestry trailers with grapples lately. Wow!
    Backwoods Savage and WinonaRail like this.
  9. Gavorosalini
    Gavorosalini
    Hutchinson KS
    Any body elses overalls get a little tighter looking at that trailer?
  10. eatonpcat
    :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol:
    JackHammer and TurboDiesel like this.
  11. Gavorosalini
    Gavorosalini
    Hutchinson KS
    Have you been able to find any prices for these?
  12. TurboDiesel
    Trucks with a 7 pin rv style plug should have wiring in place that can charge trailer batteries through a hot wire in the plug. You may just need to add a fuse in the fuse block under the hood.
  13. Lennyzx11
    Lennyzx11
    You have to be careful with that. The dump (or a winch) can try to pull a load through that wire blowing the fuse protecting it if the dump battery is low. Then no charging.
    The best way is to install a relay that disconnects the truck charging wire when the load is energized.
    Or redneck way (which I do now) is to disconnect the trailer cable when operating the dump.
    Backwoods Savage and JB Sawman like this.
  14. TurboDiesel
    My last 4 trucks have used the hot wire to charge dump trailers, tilt trailers and the camper. No problems so far but none of those use much power.
    Thanks for the tip
  15. Reddingnative
    Reddingnative
    Hornbrook, CA
    I have done the old roll and flip many times, or simply used a ramp. Mechanical advantage.... When I was really scrounging I was 27, 6’ and 140 lbs. o_O I had to work smarter not harder. Id take any firewood- big small ugly. I have the hf ramps and personally like putting plywood over it to slide big rounds up. Easier for me.
  16. JB Sawman
    JB Sawman
    pennsylvania
    The best connection for winch to use the truck batteries is a seperate plug mounted on truck similar to the plugs put on tow trucks for jumper cables they are rated for high draw and you can leave the truck running to keep all batteries up JB
  17. Warner
    I was thinking of this thread while at work today setting a new truck up to go into service. image.jpg Cables go up to the vehicle batteries. The separator keeps the external load from killing the truck.
  18. Erik B
    Erik B
    Western Wisconsin
    Does anyone use a winch powered by a garden tractor? I was wondering if the electrical system on a garden tractor would be beefy enough to handle the load.
  19. brenndatomu
    Maybe if it were a small winch, and was only used for a short time very occasionally...long/heavy pulls with a big winch, very likely a no go...the exception might be the old garden tractors that have a real alternator (generator usually) on it...and engine would need to be revved up to try to keep up with the electrical load...
  20. Mag Craft
    I use a winch on my trailer and carry a spare battery with me. I have pulled some really big stuff using that.
    Or I roll the rounds up the ramp on the trailer.
    WoodPirate and Backwoods Savage like this.
