How many times
Discussion in 'Chainsaws and Power Equipment' started by Ohio dave, Jan 1, 2021.
  1. Ohio dave
    Ohio dave
    Akron, OH
    How many times can you sharpen a chain before its been sharpened so much there's not enough left to sharpen?
  2. Redfin
    Redfin
    central Pa
    I run them till the cutters start breaking off.
  3. JimBear
    JimBear
    I sharpen mine until the teeth start breaking off when cutting. So pretty much down to nothing. I like to get my money’s worth out of them.
  4. walt
    walt
    north central ohio
    Down to a little triangle , then maybe one more time . I try to get it all
  5. The Wood Wolverine
    I usually stop at the witness mark for sharpening angle.
  6. JCMC
    JCMC
    Just outside of Shushan, NY
    I'm with all the above.
  7. brenndatomu
    Keep on sharpening until there's no more toofs left to sharpen...as far as how many sharpening's that is...depends on how bad the chain is, and who is doing the sharpening, and with what type of tool...
    Slocum, Eckie, Dakota Hoarder and 6 others like this.
  8. Redfin
    Redfin
    central Pa
    How are you Man? Eager to shake your hand again.
  9. Redfin
    Redfin
    central Pa
    And when the cutter shears, grind off the guide. Those are stumping chains.
  10. walt
    walt
    north central ohio
    I am well and looking forward to shaking hands with you.
    amateur cutter, Redfin and Sinngetreu like this.
  11. Fifelaker
    Fifelaker
    Fife Lake Mi.
    Until that last toof can't cut no more.
