Don't mind the horse, load the wagon
Discussion in 'Chainsaws and Power Equipment' started by foragefarmer, Jul 19, 2014.
  1. foragefarmer
    foragefarmer
    Central, Virginia
    This guy will take all the old fence boards and posts off of a job. I know the oak boards he has loaded up here will become reclaimed flooring. There are over 2000 cut down pieces on the trailer. I keep loading and he never says stop.
    Anyone else have an overloaded pic or two to share?
    basod, Pallet Pete, Stinny and 8 others like this.
  2. Anvil
    Anvil
    NE Wisconsin
    Wow! That is a nice looking rig.
    Is that what you've been using that 241cm for?
  3. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Slightly off topic, but your thread title triggered this thought. I am a collector of Studebaker vehicles, as some may know they were the only manufacturer to make the transition from horse drawn to gasoline power. One method they used to show the strength of their vehicles was to pair it against a competitor and load both until an axle broke. You would be surprised how much weight wooden axles and wheels can hold before failing.
    Oliver1655, Pallet Pete and HoneyFuzz like this.
  4. nate
    nate Banned
    Palmer, AK
    Normally need a strap that size for every 5000lbs. So either he only has about 15k on there or he needs several more straps.
    I'd have 3-4 per row!
    A guy that landlords a few houses near me has one of those trucks. I laugh every time he shows up cause he just uses it to tow a tiny trailer for a lawn tractor.
    HoneyFuzz and clemsonfor like this.
  5. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    He is probably 'writing off' that truck because he needs it to maintain his income producing properties (or so he tells the IRS)! Even though he tows less than a ton!
  6. nate
    nate Banned
    Palmer, AK
    I'd have to take a pic. This trailer and "tractor" is light enough that my Jetta would have no trouble towing it.
    I don't know if its lifted but it sits taller than my dumptruck even!
  7. MasterMech
    He's probably not as overloaded as you think. The trailer is certainly ok. What's the truck? Looks to be bigger than an F550? Diggin' the super singles on the rear, don't see that everyday around here.
    Oliver1655 and concretegrazer like this.
  8. clemsonfor
    Check the loaded truck thread. There a few there. Some posted by me but only on a small truck and trailer.
    Looks like good wood why give it away..and not charge a quarter a board or something or even a dollar ?
  9. foragefarmer
    foragefarmer
    Central, Virginia
    He is overloaded and said as much. 2000 half boards is 1000 full oak boards which would be 40000 pounds fresh cut from the mill. 20k trailer. the boards are lighter than fresh but not that much lighter. Maybe 25K
    HoneyFuzz likes this.
  10. foragefarmer
    foragefarmer
    Central, Virginia
    And the 241 has been earning its keep. +/- 6000 cuts last week.
  11. DexterDay
    I was thinking the same (F-550-F-650?) And the Big Singles on the rear look Slick!
    Yep.. It sure is earning it's keep!! :thumbs:
    Oliver1655, HoneyFuzz and clemsonfor like this.
  12. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Sweeeet !!
  13. nate
    nate Banned
    Palmer, AK
    Im pretty sure it would be an F650 at least if it was stock with that front clip. The 550 still has a pickup front clip.
    concretegrazer likes this.
  14. OhioStihl
    OhioStihl
    Southern Ohio
    It's great to see a truck get worked like it should.
  15. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Agreed !!
  16. concretegrazer
    concretegrazer
    Southwest MO
  17. foragefarmer
    foragefarmer
    Central, Virginia
    There ya go CG.:D Now if you had put singles on the top...
    Oliver1655 likes this.
  18. nate
    nate Banned
    Palmer, AK
  19. foragefarmer
    foragefarmer
    Central, Virginia
    Didn't I see a trailer load of logs getting pulled by a Dodge 2500 you posted the other day?
  20. nate
    nate Banned
    Palmer, AK
    Yes, but it wasn't overloaded.
    I have pics somewhere of 4 tons of gravel in my 3500. :D
