What's on the grill or smoker?
Discussion in 'The Smokehouse' started by Genius, Jun 20, 2016.
  1. Chvymn99
    12 lbs of summer sausage...
    1/2lbs & 1 lbs
  2. Chvymn99
    14 lbs .... 5 boner... my buddy and I are splitting it...
    3 - 8oz Irish butter with A bunch of garlic, a couple of sprigs of Thyme and Rosemary...
    8-10 hrs on the smoker is what I’m aiming for
    8ADA68FC-E0A5-4B7C-BB54-21AF19C5958C.jpeg C4A11A68-8D29-4C91-B51F-B2A5DD5FBCAD.jpeg
  3. Smokinpiney
    Smokinpiney
    "South" Jersey
  4. Chvymn99
    Nice... what temperature did you run at? To what temperature?
  5. Smokinpiney
    Smokinpiney
    "South" Jersey
    My pitboss will only run at a minimum of 180° on the smoke setting so i tried to keep it there. But the outside temp was in the 20's this morning so it had a hard time keeping that temp and it kept trying to flame out on me. I bumped it up to 200° and pulled the sausage off at an internal temp of 154° after 4hrs. Gave it an ice water bath for about 15mins and then let it rest at room temp for 2hrs
  6. Chvymn99
    that’s basically what program I do too... my Traeger is suppose to smoke at 160... but it never holds that.... I put mine on 180 were its forced to control temperature and does much better.... mine usually takes 6-8 hours to get upto 152 F... it’s always interesting to see the difference in models... can’t beat fresh summer sausage....:dex:
  7. Smokinpiney
    Smokinpiney
    "South" Jersey
    This was actually my first attempt at summer sausage so I was nervous about temps. I has the pitboss probe in the sausage and i also checked it with an instant read thermometer just to be safe. It turned out really good! So far the mrs and my daughter approve! :thumbs:
    I'm gonna take some in the stand with me this afternoon for a snack. Maybe it'll be good luck lol
  8. Chvymn99
    Good Luck! Sounds like a win-win ... Good Job!
  9. Chvymn99
    Just pulled mine....
  10. Chvymn99
    Just finished.... now to rest
  11. T.Jeff Veal
  12. Smokinpiney
    Smokinpiney
    "South" Jersey
    Chvymn99 what type of casings did you use?
  13. Chvymn99
    no casing.... just tightly packing in saran wrap....
  14. Smokinpiney
    Smokinpiney
    "South" Jersey
    Ohhh nice! Just rolled em into logs and smoked? Might have to try that. I bet ya get alot better smoke flavor that way
  15. Chvymn99
    yea, the wrap forms the log and setting the log form over night sets it up. The key to it is twisting the one side... then some what kneading it to get rid of some of the air pockets... then twisting the other side ...
  16. eatonpcat
  17. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    how long and what internal temp?
  18. Chvymn99
    7 hours.... 140 F....
  19. Chvymn99
    Thanks...
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    whats your rating on the butter seasoning?
