Closing the Damper...?
Discussion in 'The Wood Pile' started by Nordic Splitter, Dec 19, 2020.
  1. Nordic Splitter
    Nordic Splitter
    WNY
    This may be a crazy question but here goes.....My son leaves for work around 9:30pm every night but before he goes...He throws in a fairly good size split...I mean big.....He lets it catch on the bed of coals for about 10 minutes then he shut the damper down to 0...Yes 0!...All the way................I was under the impression that at 0 no air gets into the stove (Jotul F600) When I come down around 4am for work..There is a nice lump of cherry coals waiting for me.....What gives???? Thanks
  2. brenndatomu
    Zero is just the lowest setting...not actually zero air...the EPA did away with "air tight" stoves back in 1988...so unless your stove is older than that...
  3. Ronaldo
    Ronaldo
    Right on, most modern stoves leave enough air coming in to sustain a burn. I do believe you are operating it exactly as you should.
  4. buZZsaw BRAD
    The damper is in a fireplace. Closing that would create major problems. Ask anyone here who's ever started a fire in one with it closed! The draft at that setting must get enough air for a burn and obviously it did. I used the same protocol when i burned my insert and it worked fine although mine didnt have numbers.
  5. Nordic Splitter
    Nordic Splitter
    WNY
    Always thought the air control was called the Damper....Its the Silver knobbed lever right it front..All the to the left I would count as 0 All the way to the right I would count as 10
  6. billb3
    Both the primary (and secondary if the stove has one) air controller in the stove and the chimney damper (if there is one) can be referred to as dampers. It can be confusing.
    Most ( new stoves) the primary air control may go to a mechanical stop that may or may not be "zero".
    Most (but not all as PE has some stoves that are an exception) the primary air control does not limit the air to the secondary tubes, so there is still a supply for the fire. You really can't starve most of the newer stoves. (without modification(s)).
  7. iowahiker
    iowahiker
    NE Iowa
    My understanding is a "damper" is any device to adjust the flow of gases (draft), either air into an appliance or gas out.
    My understanding is a wood burning appliance should be designed to never become totally air tight because cooling gases can shrink and suck air down the chimney, backflow. My furnace is not totally air tight but did backflow once in the last 25 years. Air coming down a chimney and hitting burning wood/coals which are starved for air creates a startling "boom", rapid combustion. Opening the air intake will prevent a second "boom" since the process can repeat immediately. One "boom" was enough for me and so I never close my intake draft more than 75% when a significant amount of wood or coals is burning.
    Creosote in the chimney (or lack of) is a way to tell if a damper is being closed too much. Poor catalyst life would be another sign of a damper being too closed.
  8. buZZsaw BRAD
    I always remember as a kid dad would make sure the damper was open when he started the fireplace. Metal handle out of sight on the top of the fireplace inside. When i purchased my insert the seller called it a draft lever and i used that term since. My late uncle had a stove in his garage that had the damper/draft lever on the stovepipe although i dont recall what he called it. I guess they could be interchangable.
  9. oldspark
    oldspark
    NW Iowa
    "You really can't starve most of the newer stoves. (without modification(s))."
    I beg to differ, a boatload of varibles too numerous to list.
    Cash Larue and amateur cutter like this.
  10. brenndatomu
    But no matter how its labeled, you cannot close the air to actual zero on a modern stove (as it was built)
  11. oldspark
    oldspark
    NW Iowa
    No you cant but you can starve the stove, still a matter of skill and experience.
  12. Skier76
    Skier76
    CT and SoVT
    I have to have a pretty good fire going to back the air control down to anything less than half. It's due to a stove that has a 6" output going into an 8" exterior chimney, with two 90 degree bends.
  13. Woodwhore
    Woodwhore
    Mason NH
    My stove i set it and forget it!! Pull out the knob and turn to the left and as the fire gets hotter it closes the dampner and you wind up with the beautiful dancing secondary burn flames.
    Dakota Hoarder likes this.
  14. Joe P
    Joe P
    Wisconsin
    I'm thinking about putting an additional damper on my flue coming out of the stove. I have an enerzone 3.4 and about 25' of flue. Even when the stove is damped all the way down on the stove, it still runs pretty hot with a full load, especially now that I'm burning really dry wood. I've think with the amount of chimney I have I've got some overdraft going on. I just need to find time to install the manometer I have to verify.
    brenndatomu likes this.
  15. brenndatomu
    I suspect you are on to something...
    moresnow likes this.
  16. oldspark
    oldspark
    NW Iowa
    About 15 feet of straight up chimney, i can make the fire go out by turning it too low.
    Skier76 likes this.
  17. Ronaldo
    Ronaldo
    I have a Pacific Energy Super 27 stove and I run it in a very similar fashion as the OP. I get a good fire going and char the wood then shut it down all the way to leave for work or for overnight burns. This is exactly how my owners manual directs for long sustained burns. It work great for me.
  18. ReelFaster
    ReelFaster
    S.Jersey
    This......
    While digging around looking at it once on my insert I saw about a dime sized hole in the plate the knob controls that opens and closes, allowing the air intake. I went digging because I once had it completely closed but could subtly hear air being sucked in, thought something was wrong but did more research and learned what brenndatomu stated above.
  19. oldspark
    oldspark
    NW Iowa
    I had a PE stove and it said to set the air to desired setting for long burns, this was to be found by trial and error.
  20. Sourwood
    Sourwood
    Popcorn, IN
    Oddly enough we have had a strong steady wind today, blowing right at the damper to my boiler. Got home and temp was at 205.
    I checked the seal and it seems okay, so thinking maybe there is a slight gap on the damper. I have a trash bag covering it as an experiment. Only challenge the weather is warm, too so the furnace hasn’t been running to bring the water temp down.
