What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. J. Dirt
    J. Dirt
    May....Echo 590 turned into a 620PW
    1F15125D-5204-4266-AF72-8BE94D0C617A.jpeg 30EE3CCB-6DE9-4206-9703-2724B3505AB8.jpeg A8837E11-F46C-4B36-8393-35620165A4A6.jpeg BA089B3D-3733-4709-8D30-56AF87325778.jpeg
  2. Czed
    Czed
    Wv
    Working on a 36 50 and 257 IMG_20201022_173522.jpg IMG_20201022_173545.jpg IMG_20201022_180710.jpg
    The 028 weighs near double what the 257 weighs
    And the 257 far out cuts it.
  3. M2theB
    M2theB
    Central Massachusetts
    metalcuttr and J. Dirt like this.
  4. J. Dirt
    J. Dirt
    Haha getting there! As for projects I got November’s today! 395xp and a 288!
  5. M2theB
    M2theB
    Near the bench
    65D51B79-06C9-4F9B-BAF3-F2FB2400F069.jpeg 91F7370A-C525-4664-94B4-CA4A43F678B0.jpeg
    replaced the Cub Cadet PTO clutch this afternoon and drive belt.
    Leave mulching tomorrow.
  6. M2theB
    M2theB
    8DA165A4-DBA2-47CB-B958-3DF5DB3F4063.jpeg Picked this one up today
    F2F68FA0-3347-4684-B9ED-64CE57ADACDC.jpeg 600B2723-F366-4328-AFC3-E72B143D9B09.jpeg
    add did say it needed a new chain.
    I don’t think it’ll need much
    fuel line. It also has the plastic clip intake that ill metal band
    I’d be 100% tickled with it except the front AV seems to be stripped from the tank. Have to figure if there’s away around that without replacing the tank. That was worth a discount though.
  7. huskihl
    huskihl
    A new chain won’t cut backwards either lol.
    You can melt the hole full of weed trimmer line and redrill the hole. Or shove a piece of trimmer line into the hole and run the screw in for a quick fix
  8. M2theB
    M2theB
    That’s worth the shot. Thank you sir.
    I debated whether to mention it, the chain, but not for long. Pointing it out wouldn’t make either one of us better off.
    J. Dirt likes this.
  9. huskihl
    huskihl
    No sir, it wouldn’t. Unless the owner thought that was the reason it wouldn’t cut and needed to be replaced
  10. M2theB
    M2theB
    Nope, bad back and too much for him. We never talked about how it cut or that it could start but wouldn’t run other than he said it needs a tune up.
  11. The Wood Wolverine
    My favorite chainsaw. Does it have the auto decomp?
    J. Dirt, Sandhillbilly and M2theB like this.
  12. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    And let me guess.... gave $75 for it
    J. Dirt, M2theB and cnice_37 like this.
  13. M2theB
    M2theB
    It does have the auto decomp blueberry, 2000 I think, 00
    And I got $75 to haul it away! :D
    Markds2, J. Dirt and huskihl like this.
  14. Diesel 4 life
    Diesel 4 life
    Kansas
    J. Dirt likes this.
  15. Czed
    Czed
    Wv
    I was given this 025 that has been setting for many years.
    No fuel residue or odor left at all.
    It's a very low hour saw
    It just needs a fuel line I have one around here somewhere
    And I have a new carb.
    I'm converting it to 3/8
    I just got the sprocket kit. IMG_20201213_120222.jpg Oddly it had that plastic orange t
    I got a 16" upstart bar and 4 chains
    I've run the 3/8 full chisel for year's
    It's been good.
    Nixon, Sandhillbilly and M2theB like this.
  16. M2theB
    M2theB
    I haven’t seen or heard of that T
    What is it?
    Sandhillbilly and Czed like this.
  17. J. Dirt
    J. Dirt
    Well I picked this one up with a bad p/c as a 590. It’s was only a few months old and just like new otherwise. It was a good buy and I was going to rebuild it anyhow so why not make it into a 620?!
    All said and done you’ll spend just as much as a new one... so just to make the swap it’s probably not worth it. It was a new p/c, coil, handle bar and some screws and pieces to fit the handle. It’s a killer saw though all said and done.....
    Diesel 4 life, Czed and M2theB like this.
  18. J. Dirt
    J. Dirt
    Poulan pro p65.
    Sporting a 655BP p/c 8E44D078-A8DE-4A18-85CB-B004E66992AE.jpeg 2D7AF4A3-0B34-467E-88C1-A69B2CEAD42C.jpeg
  19. Czed
    Czed
    Wv
    No idea doesn't belong in a saw
    Some kid playing with it maybe idk
    M2theB likes this.
  20. Diesel 4 life
    Diesel 4 life
    Kansas
    Yeah I really like my 590. I have thought about just putting the unlimited coil on it. I’ve heard it really makes a difference.
    J. Dirt likes this.
