I Always Wanted to get up in the Bucking World!
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Dec 6, 2020.
  1. buZZsaw BRAD
    Rarely will you see me have a PU full of longer length logs, usually they're bucked to my my standard 16". Being smaller sized it was logistically easier to load the locust i cut on Friday in 8' pieces.
    Normally ill just drop them on the ground and prop on a round to buck when home. Works okay for a few but not a PU full. Got creative with an old wood ladder ive been meaning to cut up and burn outside in the pit. Propped it on a couple saw horses and put the lengths on top a few at a time to buck. Worked pretty good. A few bigger 4' chunks i bucked on the ground.
    If i had a permanent processing area id make a nice sawbuck/sawhorse, but i make do/improvise when needed.
    I always wanted to get up in the bucking world...not exactly what i had in mind.
  2. MikeInMa
    If it works, then buck away!
  3. Haftacut
    Haftacut
    Rives Junction, MI
    It appears you have got up in the bucking world! Bet your back is thanking you! Looks like it worked well for you. We’re the lengths hefty getting them into the truck?
  4. buZZsaw BRAD
    They were. Even harder getting them off, plus it rained good here yesterday and they were slippery yet. Any other wood idve left it. Dang locust mania! Back was thanking me!
  5. The Wood Wolverine
    The wood that I am currently burning was a lot of 15” and smaller trees. I cleared a lot for a friend to build a house on. He wanted it clear ASAP, so we brought home a lot of 8’ lengths. Then my son was never around to help process, so I found one of these for sale locally. It worked great.
    Forest Master 80-934 Ultimate Saw Horse
  6. The Wood Wolverine
  7. buZZsaw BRAD
    I clicked on your link and watched it. Pretty nifty gadget. How much wood did you get at the time Jason?
  8. amateur cutter
  9. Haftacut
    Haftacut
    Rives Junction, MI
    I can blame you brad! Id have stopped too:thumbs:
  10. The Wood Wolverine
    Check this thread out: Lot clearing score.
    Shows the mound of length logs I had. That saw buck really worked well for me.
  11. buZZsaw BRAD
    That was quite he score. Im not used to seeing you buck smaller wood. How much did you end up getting out of their cordwise?
  12. EODMSgt
    EODMSgt
    White Mountain Region, NH
    That's an interesting contraption. I've had a Logosol Smart-Holder saw horse for about nine years and have used it a lot for smaller logs. Thankfully I have the tractor with grapple for the large stuff now. Still, that Forest Master is a neat idea.
    Smart Holder | LOGOSOL - YouTube
  13. The Wood Wolverine
    I believe it was about 4.5-5 cord. Lot of it was SBH. It’s damm fine firewood!
    The guy I bought it from had one like you posted too. It was an toss up, and the chain style won.
  14. EODMSgt
    EODMSgt
    Good choice, you'll get a lot more out of the chain style. The Logosol will only allow up to a 9" log and I've actually tweaked the upright from using it with heavy logs over the years. Still works great but had the Forest Master been available back then, I probably would have purchased that instead. The good thing about the Logosol is that it folds up to almost nothing so is easy to haul/store.
  15. LordOfTheFlies
    LordOfTheFlies
    NY
    Nice! I have an old fiberglass extension ladder I don't ever use just lying next to the garage. Seeing as I have in inbound load of 8' beech logs I might try something similar....except a 15" dbh 8' log of beech is pretty damm heavy....
    Midwinter, buZZsaw BRAD and Chvymn99 like this.
  16. buZZsaw BRAD
    May not work good with fiberglass as the saw does nick the rails. Yeah a log that big you probably wont be able to lift up onto it...unless you want a hernia for Christmas :pain::santa:
    Midwinter likes this.
  17. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I've got one of these that I'm either going to sell or put up as a door prize at a GTG once the Covid bug is under control.
    They're pretty cool. I bought it for a special job and no longer need it.
