Green oak
Discussion in 'The Wood Pile' started by GRIZ, Jul 16, 2014.
  1. GRIZ
    GRIZ
    What would be yalls choice of seasoning oak? Cut, busted, and stacked in November - December
    Here is the 3 ways I keep my wood.
    1 Big building with the front and back open.
    2 Small building completly shut of unless door is open.
    3 Stacked in single ricks and top covered,
    HoneyFuzz and Stinny like this.
  2. mattjm1017
    mattjm1017
    I would venture a guess that most folks around here will lean towards option 3. Ill be trying that out this year the last couple years I have stacked in an almost cube thing and have found that the center was wetter than the rest.
    OhioStihl and Stinny like this.
  3. Stinny
    Oak... 3 years... open as possible stacking, off the ground, top covered... :yes:
    Gark, HoneyFuzz, MasterMech and 3 others like this.
  4. Fanatical1
    Fanatical1
    X 2
    Gark, Chvymn99 and Stinny like this.
  5. DexterDay
    If cut in November or December? I would stack it outside in any manner possible. Then after 2 years, I would put it in option #1.
  6. lukem
    3...wait 2 years...then 1....then wait a year and burn.
    Gark and HoneyFuzz like this.
  7. clemsonfor
    I live in the south and I can get away with 2years of summer seasoning. That works best on a dead tree. If cut green/living even this is pushing it. But I would stack in open covered then under a cover.
  8. Chvymn99
    Oak definitely needs all the open wind and sun it can get for 2 or 3 years while being top covered.
  9. Backwoods Savage
    For years we have cut in winter, split and stacked in spring. When stacking, we lay down some poles to keep the stack off the ground. We do not top cover the wood until late fall or early winter, usually around December 1 or Thanksgiving or thereabouts. For top covering, we like to use old galvanized roofing. In addition, we really try to make sure all our wood has been in the stack for 3 years or even longer. The benefits of this are tremendous.
    Christmas-2008b.JPG Christmas-2008d.JPG Denny-April 2009i.JPG May 2014-e.JPG Wood-3-4-10b.JPG
    Drvn4wood, milleo, GRIZ and 6 others like this.
  10. Stinny
    Like that pic of you n' the stacks... :yes:
  11. Backwoods Savage
    And just who said that ugly guy was me?
    milleo, Chvymn99, Stinny and 2 others like this.
  12. papadave
    No where to run, no where to hide.......
    We know who you are.:thumbs:
  13. bogydave
    +1
  14. GRIZ
    GRIZ
    Backwoods you got it down pat for sure !! Good looking pictures !! I have burned wood of and on for several years since being on my on and in the house I live in now last year was my first and I went wild cutting wood and have about 15 cords but past this winter I will be looking at all 2 year old oak. But after that I will be nothing under 3 year old for good. Thanks buddy you have been a big help.
  15. Stinny
    Backwoods Savage is the go-to-guy for firewood experience.
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Usually dont get too much Oak to worry about up my way . Mostly Ash ...some Maple and Cherry . But in my other post..Ill have a "big" Oak to deal with soon :)
  17. Gark
    Gark
    SW Michigan
    +1
  18. Sinngetreu
    Sinngetreu
    North Central Iowa
    My method (currently) is a holz hausen. Its just one more way to do it. 2014 Holz Hausen 009.jpg
    This is a stack of Ash that was cut last fall, split in early spring, and built in May. It should be ready in late fall. Its completely gray as we speak (er um... type). It will work for Oak too with three years dry time.
    clemsonfor and Backwoods Savage like this.
  19. Backwoods Savage
    It will work okay Sinngetreu, but it is a lot of extra work and the only benefit is a neat looking stack. But if you like them, go for it!
    nate, Chvymn99, GRIZ and 1 other person like this.
  20. clemsonfor
    I am with you savage...dont see much point to the stacks but do out if you like?
