Chainsaw Bar Oil Preference?
Discussion in 'Chainsaws and Power Equipment' started by Lastmohecken, Dec 2, 2020.
  1. Lastmohecken
    Lastmohecken
    Arkansas
    Now that the weather has cooled off a little bit, and my saws are a little stingy anyway, it seems. I suspect that the cheaper Tractor Supply oil is maybe a little thick.
    What's your favorite bar oil for cooler weather, not freezing cold weather, but lets say mid 30's to high 40's? This has probably been done to death but I didn't have much luck when I tried a search.
  2. JimBear
    JimBear
    The only time I use a different oil is if the temps get down around 20* or less. I have some winter weight for that. I would suspect that at the temps you are talking about it won’t make much difference. Most of what you get at a TSC, Menards, etc. are going to be all season oils. As long as you are seeing normal oil usage I wouldn’t worry about it, unless you are scorching your bar.
    Fanatical1, mat60, papadave and 3 others like this.
  3. buZZsaw BRAD
    I use the same stuff year round. TSC is usually what ill buy...when i can get it.
    Bar Oil Shortage?
    mat60, jrider and In the Pines like this.
  4. huskihl
    huskihl
    As long as it will pour into your saw, it won’t matter how thick it is after a few minutes. The heat from the saw will warm the oil regardless of air temperature.
    That being said, the thickest I’ve ever seen was the square jugs of FVP from Menards. It would not come out of the jug at 20°. I just thin it out with kerosene or mineral spirits when it gets that cold if I don’t have any thinner bar oil to use
    Fifelaker, Ronaldo, mat60 and 6 others like this.
  5. papadave
    Seems like I've seen "winter" oil at TSC, but I don't remember. As huskihl said, I just use the same oil and it warms up and flows after the saw gets used a bit.
    mat60 and huskihl like this.
  6. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Like everyone else, I just use whatever, Menards or TSC. Generally the oil sits in our attached garage at around 65+f so already warm.
  7. Ward Hoarder
    Ward Hoarder
    West Virginia
    I really like the orange jug of Extreme oil sold @ Rural King and Tractor supply.
    Stephiedoll and Chud like this.
  8. Lastmohecken
    Lastmohecken
    Arkansas
    Ok, so lets just say that I wanted to thin out the bar oil a little bit from Tractor Supply with diesel fuel because it is the most convenient thinner for me. I just am not that impressed when I look for oil flying off of the bar when I check it. How much diesel would you add to a tank?
    buZZsaw BRAD likes this.
  9. JCMC
    JCMC
    Just outside of Shushan, NY
    I use the TSC year round never had an issue. I did buy a gallon of the TSC winter weight a two years ago really didn't see much difference in usage, but as the others say once you fire up the saw the oil warms and flows.
    Ronaldo likes this.
  10. Erik B
    Erik B
    Western Wisconsin
    When I go out cutting, my bar oil is in a Dawn dish detergent bottle. If I am cutting in cooler temps like what we are having now with highs in the 40's, I will put a slug of winter weight oil with the regular summer oil. Anyone else do this?
  11. JimBear
    JimBear
    If you have a NAPA near you the jug on the right is winter weight b/c oil. Part number is on the upper right of the tag. It will be cheaper than Stihl winter weight.
  12. buZZsaw BRAD
    Your two stihl saws have adjustable oilers. If your concerned turn it all the way up
  13. Lastmohecken
    Lastmohecken
    Arkansas
    They have been turned up all of the way for some time. And yes, I have cleaned the bars and oil holes. My Jonesred CS 2255 will spray some oil off of the tip of the bar, like I think it should, and the 261 not as much, and the 362 not to much at all, as it's pretty hard to detect, however I know it using some as I end up using probably 1/3 of an oil tank full to a gas tank maybe slightly more but I doubt it uses half a tank. And the chain just seems like it ought to be a little wetter.
  14. Lastmohecken
    Lastmohecken
    Arkansas
    I may look into this. I like the idea of going to a winter grade if it's not too expensive.
  15. Farmchuck
    Farmchuck
    Nepa
    I like Itasca. Both summer 30wt. & winter 20wt. Both are good and stingy/ tacky.
    JimBear likes this.
  16. B.Brown
    B.Brown
    USA
    Anything that's sticky!! and i normally dribble a little on the bar when i first start the saw up as well.
