A bit scarey dontcha think??
Discussion in 'The Pellet Bag' started by Tullytown, Nov 27, 2020.
  1. Tullytown
    Tullytown
    North of Phila Eagles.
    Screenshot_20201127-045012_Facebook.jpg maybe a bit too close.
  2. stuckinthemuck
    stuckinthemuck
    Either way, those pellets will heat your house... one method would just heat it a lot quicker And you won’t have to bother loading the furnace...
  3. PelletHound
    PelletHound
    SE Ma.
    I'm surprised the plastic bags aren't melting.:eek:
  4. justdraftn
    justdraftn
    On the road
    Must be a zero clearance stove.
    ....tak'n it to the limit.
  5. Horkn
    That is literally playing with fire.
  6. bogieb
  7. peterfield
    peterfield
    Darwin lives!
  8. eatonpcat
    If they were Green Supremes, I think that would be a great fire retardant!
    Bucks Pellets, Earl764, mat60 and 6 others like this.
  9. unbidden
    unbidden
    RI
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    at least theyre vermonts
  11. Pete Zahria
    Pete Zahria
    New Hampster
    Yes.
    That cord should be coiled up.
    Dan
    Earl764, mat60, CleanFire and 2 others like this.
  12. ttdberg
    ttdberg Pellet Pig
    CT
    Also, I don’t see a surge protector.
  13. Tullytown
    Tullytown
    Must not be lot of heat from the sides because i would think the bags would melt a bit..but maybe not..
  14. jtakeman
    I just want to know who's the SOB that went in my basement and took pic;'s of my dandy setup without asking permission. :BrianK:
  15. CleanFire
    CleanFire
    :whistle: ... I think you should move 'em a bit closer, still got plenty of room. :thumbs:
  16. subsailor
    subsailor
    Winthrop, Maine
    It can't be your basement. You're too cheap to buy Vermonts.
    Earl764, RIburn, MikeInMa and 8 others like this.
  17. jtakeman
    RIburn, CleanFire, ttdberg and 3 others like this.
  18. badbob
    badbob
    Possibly.But that is a ducted furnace,and there are upper and lower ventilation holes in the side panels, and pictures can be deceiving. Some years,like now,I stack pellets 14" away from my Accentra.BUT,they are gone by the time hard winter comes in,and,my cabin is small,and stove rarely runs on high for more than 30 minutes,except when hard winter moves in.
    mat60, slvrblkk and bogieb like this.
  19. bogieb
    From the manual I pulled up for Accentra, the side clearance is only 12" to combustibles, so technically 14" is fine.
    The picture makes it look like those pellets are awful close, but the clearance for that particular model might be fine. I just tend to think about my P43 & P61a clearances (without shields) which are definitely further than that. Heck, even with the shields, the P43 has a clearance of 14" and even though the wall next to it is that distance, I elected to put up a heat barrier on the wall because the drywall got a little too warm for my comfort.
    mat60, PelletHound and slvrblkk like this.
  20. Rich250
    Rich250
    Berks County PA.
    That stove is a Drolet eco 65 and only has a side clearance of 6" so your right Bogie that stash is more then 6" away. I would never store my stash that close but to each there own.
