Well that was fun
Discussion in 'The Wood Pile' started by Reloader, Nov 25, 2020.
  1. Reloader
    Reloader
    NW Oregon
    Doesn’t look like much to you young guys but still a work out for this old fart. Got most of the downed stuff buzzed up.
    Found this 488 on the shelf and didn’t even remember buying it. Might be the first time I’ve given it any work. Ran great. I have no idea where the bar came from.
    The smaller stuff was in pretty good shape. The bigger moss covered log wasn’t too bad except for the top pieces. Will be fine if I get it seasoned and burn in Winter next year.
    A little drizzly rain but it felt good to spend some time in the woodlot.
  2. Sinngetreu
    Sinngetreu
    North Central Iowa
    That looks pretty buried. Was it as solid as it looks?
  3. Chud
    Chud
    Dang someday I hope I find a like new saw that I forgot buying. :thumbs:
  4. papadave
    Looks like the log needed a haircut.
    Not a bad haul.
  5. Reloader
    Reloader
    NW Oregon
    Was actually up in the air until last week. Not the best but pretty solid except for the first couple of cuts on the upper end. Will be okay for Winter 2021.
  6. Reloader
    Reloader
    NW Oregon
    Looked at my list and seems I got it in 2018 for $150. Guess that’s not too bad for a good running Shindaiwa 488. Even though I’d probably opt for a 577 if I could only keep one saw, the 488s and 500s have cut more wood for me than any other.
    The 577 has a bit more power so does better in bigger wood.
    brenndatomu and Chazsbetterhalf like this.
  7. Gpsfool
    Gpsfool
    U.S.A.
    That moss puts out good heat?
  8. Reloader
    Reloader
    NW Oregon
    Not much but it makes starting the fire easy.
  9. buZZsaw BRAD
    Im starting to appreciate the smaller rounds. Do you remove the moss when you split Reloader ?
    EDIT: didnt read all responses prior to posting.
    brenndatomu likes this.
  10. Bill2
    Bill2
    New hampshire
    Now that's a nice find. Both the wood and the saw!
  11. Sinngetreu
    Sinngetreu
    North Central Iowa
    Thats great that you were able to save it before it slipped away! Nice little haul.
  12. Reloader
    Reloader
    NW Oregon
    Whatever falls off on its own while splitting. A lot of times it is easy t peel off before cutting but this was coming off in little pieces. Doesn’t hurt anything to leave it and it burns fine once dry.
    Sent from my iPad using Tapatalk
    buZZsaw BRAD likes this.
  13. Canadian border VT
    Best answer :yes:
