Wood ID
Discussion in 'The Wood Pile' started by Hookedup24, Nov 16, 2020.
  1. Hookedup24
    Hookedup24
    Bucks county, PA
    This was collateral damage from the loggers. Any guesses?
  2. Farmall340
    Farmall340
    Northwest Connecticut
    Shag bark hickory
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    X2 awesome stuff!
  4. grandgourmand
    grandgourmand
    Ontario
    Hickory...of the bark is shaggy variety
  5. Hookedup24
    Hookedup24
    Bucks county, PA
    Thanks guys. Maybe I am just used to larger trees that really have the bark curling away from the truck. The green also through me off.
    It wasn’t too bad to saw through. It is all splintered near the root ball, but there is about 25’ of trunk before it “Y’s” into two 30’ limbs. Should net 3/4 of a cord.
  6. looks like hickory to me
  7. sirbuildalot
    sirbuildalot
    Mass
    The others beat me to the punch. Definitely Shagbark
  8. Funonahonda
    Funonahonda
    Central ohio
    That wood is awesome stuff.
    Horkn and Backwoods Savage like this.
  9. MAF143
    MAF143
    North Central OH
    It takes a pretty good hit to splinter hickory. Must have had a biggun fall on it.
  10. barns1
    barns1
    Cedar Hill, Missouri
    Shagbark it is. Have three of them in my backyard. Save some of the bark, soak it in water for 20 to 30 minutes, then put it on your charcoal grill. Makes your Q so much better.
  11. buZZsaw BRAD
  12. Backwoods Savage
    Congratulations!!!
    Once you get it split and stacked, give it good time to dry right but even then do not get in a hurry to burn it. Save that stuff until you are having one of those super cold spells with below zero weather and burn it then.
    yooperdave, Horkn, Boogeyman and 3 others like this.
  13. Hookedup24
    Hookedup24
    Bucks county, PA
    I’ll try and get a picture next time I am out in the woods. All trees taken by the loggers had a diameter of 24” or greater. A few were 4’-5’ across.
    Horkn, MAF143 and Maina like this.
  14. Hookedup24
    Hookedup24
    Bucks county, PA
    I am between homes right now so not burning wood. This may get lost in the shuffle as there is probably 75 cords in tops and rootball cutoffs on the ground.
    Horkn, MAF143, Maina and 1 other person like this.
  15. Backwoods Savage
  16. Hookedup24
    Hookedup24
    Bucks county, PA
    The shag has been slayed. Some of the trunk rounds are almost “squares”. upload_2020-11-19_15-48-6.jpeg upload_2020-11-19_15-48-39.jpeg upload_2020-11-19_15-49-7.jpeg
  17. sirbuildalot
    sirbuildalot
    Mass
    Nice load!!!
    Shag is heavy stuff. Your truck will know its there.
    Horkn likes this.
  18. Hookedup24
    Hookedup24
    Bucks county, PA
    Thanks!
    My back new it was there when I was walking the rounds 40 feet to the truck. The truck only had to go 100 feet to the pallets I am stacking them on.
    Horkn likes this.
  19. Horkn
    If there's any way you can save the shag for future use, do it. That stuff is pretty much the best firewood that you can get.
    yooperdave and Farmall340 like this.
  20. buZZsaw BRAD
