Follow The Build Of The Member Created Custom Saw
Discussion in 'Chainsaws and Power Equipment' started by KilliansRedLeo, Jul 14, 2014.
  1. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Had a little time today, so thought I would get some basic things done on the custom Member Designed saw.
    The first picture is all the tools required to completSeal drivers and plastic mallete the lower end build.
    Left to right top to bottom:
    • Husqvarna Crankshaft Installation tool
    • Metric wrenches for crankshaft installation tool
    • Plastic mallet and seal drivers
    • 4mm T handle
    • 3/8 ratchet
    • 4mm allen socket
    • Razor bladt for trimming case gasket
    • Metric Torque wrench.
    Second picture is all the parts required top to bottom:
    • New OEM crankcase with bearings already installed note how the bearing on the flywheel side of the case sits deeper in the case than the clutch side.
    Third picture is new OEM crankshaft, case gasket and new crankshaft seals
    The fourth picture is everything set out for the assembly note also the two small silver cylinders in the gasket, they are the crankcase locating pins which do two things help hold the gasket in place and insure that the case goes together square.
  2. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Nice !!!!
  3. Chvymn99
    :thumbs:..... Pictures are great. This has been a fun experience....
  4. splitoak
    splitoak
    jefferson co wv
    I jus wish i liked huskys..:rofl: :lol:.....jus kiddn .lol.very nice
  5. JRSDWS
    JRSDWS
    Central Illinois
  6. DexterDay
    :popcorn:
    My subscription. . :)
  7. bryanr2
    bryanr2
    Just setting up :firepit:.
  8. concretegrazer
    concretegrazer
    Southwest MO
  9. lukem
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OK, some progress made:
    Installed new crankshaft
    Buttoned up the case with new gasket and torqed case bolts
    New seal installed Flywheel side
    Installed tank/handle unit.
    That is all for now until some minor parts come in and we know what carb we will be using.
    papadave, basod, mdavlee and 4 others like this.
  11. bryanr2
    bryanr2
    coming together beautifully.
    DexterDay and Chvymn99 like this.
  12. DexterDay
    Looking good. Are all the parts going on the saw gonna be New ? Or will some parts be used (clutch, oil pump, flywheel, etc).
  13. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    There will be some used parts probably oil pump, coil and flywheel. Rest are new. If I have good used I cannot see running the cost up by using new when used will do. I want people to be able to afford the saw. Using all new parts no matter how custom the build would make the saw cost more that going out and buying a new one in a box.
    Chvymn99 and bryanr2 like this.
  14. DexterDay
    That's what I figured. If all new, it was gonna be an outrageous price.
    I'm all for good used parts. Makes the price much more gooder ;)
    papadave, Chvymn99 and bryanr2 like this.
  15. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    well, when you figure out that there are almost 100 screws of various sizes in the saw at an average of $1.34 each, you can see how fast it mounts up. There are certain things that I will not use used parts for, any of the safety features are always new, on this saw carb is new as are crank, C/P, cases, covers, tank/handle, starter, bearings/seals and intake tract.
    Bottom line is: once you start, tune and make a couple cuts to verify the tune, everything in the saw is used.
    bryanr2, Chvymn99 and mdavlee like this.
  16. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Had a little time at the end of the day, so knife edged the transfer port entrys.
    bryanr2 likes this.
  17. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    OBTW XPW 51.4mm pistons use two rings, I will install the piston with both rings. If you and your porter want to run a single ring that is your decision. Also used a gasket because if the saw is ported then they will either nix the gasket or cut the base and besides Mdavlee likes gaskets!
  18. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Top end is on but do not have a top handle for it yet, so can't hold it tight enough to get a good compression reading, but it is up there! Tomorrow Vac-pressure tests and set the flywheel gap and finish up the wiring.
    mdavlee, Chvymn99 and DexterDay like this.
  19. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Got a little further along. Still waiting on HVA for some small parts but here is where we are.
  20. DexterDay
