A little after work scrounge.
Discussion in 'The Wood Pile' started by Sinngetreu, Nov 18, 2020.
  1. Sinngetreu
    Sinngetreu
    North Central Iowa
    Today during lunch I was out looking at some pine trees in the grove and found some hung up dead Mulberry. So of course I had to go and get it after work. Here is the result of my screwing around. My camera quality is not the greatest, but those that complain can send me a new one! :D
    I took a six inch piece and split it and it meters at 16 percent. I did have some weird chain stretch though. After making a few cuts the chain would stretch out a bit and then after setting for a minute or two it would go back to a good tightness. Not quite sure what to make of that. Its not a very good chain though, and I needed to get this load in.
    Anyway, there's some more smaller stuff left that I will go back and get when I get a chance. Its hard not to feel a pressure to go get it even though its been back there for a long time. The only difference is....now I know about it and snow is coming.
  2. Chud
    Chud
    A bent link, driver, mashed driver from chain jump, or worn drive sprocket can all cause loose tight loose chain.
    Chazsbetterhalf and Sinngetreu like this.
  3. Chud
    Chud
    Jacked up double post edited
    Spencer and Chazsbetterhalf like this.
  4. buZZsaw BRAD
    nice little scrounge! Is that ready to burn?
  5. Sinngetreu
    Sinngetreu
    North Central Iowa
    Yes sir, it is! :D
  6. Sinngetreu
    Sinngetreu
    North Central Iowa
    The chain is a different chain from when I had the chain jump last week. I did double check it and this chain seems fine (other than being a safety chain). I need to do a little look into the sprocket. It could be goobered up but its hard to tell without taking it apart from the saw.
    Chazsbetterhalf likes this.
