Beech is a real beech.....
Discussion in 'The Wood Pile' started by LordOfTheFlies, Nov 14, 2020.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Beech score baby! FBMP came through. Super nice guy. I talked to him a while and told him he should keep some of it. He has a fireplace and has some rounds stacked but nothing split as of yet.
    He said I looked real professional with all my gear. Hahaha.
    Beautiful stuff. Took 10 rounds home that I bucked onsite to 16". Will go back for more Tuesday. Now I'm off to the Marriott to get the rest of the poplar.
    The Stihl performed great. I did have to switch the chain out after I got dirt once....and also one time the carb wasn't reacting to the throttle....it almost sounded like a muted rev.....but I shut it off and started it again and it came back.
    The peavey and the cant hook came in real handy. Marked the logs with my magnetic measuring stick and went to town on that beech!!
    IMG_20201114_112916.jpg IMG_20201114_112920.jpg IMG_20201114_112259.jpg IMG_20201114_123702.jpg IMG_20201114_133323.jpg
  2. MikeInMa
    Yup - nice looking rounds, for sure.
  3. Eckie
    Eckie
    If i remember the beech ive had before, it was "fun" to split by hand. If i were you, i think I'd try busting it real soon while its wet...seemed worse when it had had time to dry a bit
  4. MikeInMa
    Beech splits ok. Not as nice as oak or maple, IMO,
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    Last time I gave up pretty fast by hand and went to the splitter.... I will see how it goes this time around.
    Man it is so satisfying sharpening your own chains and then seeing the performance in the saw come through.
    Dulled 2 chains in the dirt. First one wasn't bad. This second one was hit worse. Second pic shows the damage to the teeth.
  6. Maina
    Maina
    Nice looking beech. Looks straight with no limbs and if so it should split easy. It’s rare to find one like that around here unfortunately :rofl: :lol: It can be nasty when it’s twisted and full of knots
    jrider, Spencer, Midwinter and 7 others like this.
  7. Bill2
    Bill2
    New hampshire
    Beech-My favorite firewood. I'd take it over Oak.
  8. Maina
    Maina
    Absolutely! :thumbs:
  9. M2theB
    M2theB
    Central Massachusetts
    Noodles on the Beech
    seems kinda soapy, only way I can think to describe it and it noodle really well.
  10. buZZsaw BRAD
    X2 and sugar maple!
  11. buZZsaw BRAD
    Some nice rounds. Great score LOTF! It should hand split nice if done before ends start to check. Of course you have the hydro for back up! Chains didnt look bad at all IMO!
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah I'm going to split it on Monday. No log splitter usage on Sundays and instead of pushing myself too much today I ended up just sharpening the 2 chains I dulled. They didn't look so bad but what I meant was I hit dirt....so they just didn't cut...the tooth was kind of bent down slightly. I didn't take a good picture of it.
  13. LordOfTheFlies
    LordOfTheFlies
    NY
    I figured out what happened with the throttle not responding - it ended being a small wood chip or something that was binding the sprocket to the point where the chain was not moving at all. I didn't do the push-into-a-round-and-then-pull method but used a file to free the sprocket. Hopefully the bar is ok. It happened twice today. Otherwise the 028 was a beast. I couldn't believe how big the chips were flying off the beech log whilst bucking.
  14. brenndatomu
    When the chips start to build up under the cover I just let the saw hang straight down and rev it a little...that usually clears things out...if its too jammed up to move then try to get the chain moving by pulling or pushing the bar across a log while pushing down (for better "traction") until it will go when you hit the throttle.
  15. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah sorry I wasn't clear it was build up on the nose end of the bar at the bar sprocket not under the cover.....With me holding just the bar and chain I could not move the chain at all so I knew it was bar sprocket that was stuck. End up just going back and forth with a file and it broke free.
  16. T.Jeff Veal
    Nice rounds, good looking tree. Glad you are liking the 028.
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    I'm not liking it........I'm LOVING IT BABY! Thanks to everyone who helped me getting it up and running. I appreciate all the input (even if I don't listen to it! Haha!)
    So I ended up splitting all 10 rounds of the beech today by hand. It wasn't that bad because this score was straight grained with a few knots here and there.....but overall I'd say it was something like splitting sugar maple.....Not as easy as red/black oak for me or black locust.....but not too bad indeed.
    Last pic is of the poplar - had to use just one wedge and sledge and a few taps for that but it was easy compared to trying to whack at it with the x27 which just sunk in. Once split in half I was able to use the x27.
    2020-11-15 12.36.05.jpg 2020-11-15 12.37.31.jpg 2020-11-15 12.45.48.jpg 2020-11-15 12.53.21.jpg 2020-11-15 14.17.20.jpg
    T.Jeff Veal, Maina, Woodwidow and 6 others like this.
  18. buZZsaw BRAD
    I compare beech and sugar maple in terms of splitting ease. Did you get the rest LOTF?
    That poplar looks better than i thought it would.
  19. LordOfTheFlies
    LordOfTheFlies
    NY
    Yeah I agree with the beech and sugar maple for sure.....
    I'm going back on Tuesday for the beech......and waiting for the skid steer for the rest of the poplar.
    That popular is pretty clean, almost artisanal one could say. :rofl: :lol:
    T.Jeff Veal, brenndatomu and Spencer like this.
  20. LordOfTheFlies
    LordOfTheFlies
    NY
    Most of the tree was off the ground, and the part that was on the ground was all rotted so I started from that point on.
    And the bark just peeled off in huge sheets on the log....which made trying to pick up those 22" monstrosities a bit on the hard side.
