How the mighty have fallen
Discussion in 'The Wood Pile' started by rainking63, Oct 1, 2020.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Volume of a circle = Pi * Radius Squared.
    Volume of a cylinder = volume of a circle * height.
    Since a holz hausen curves slightly towards the center, you lose a bit, so yeah, it's a bit of a guesstimation....But my 8' diameter x 6' height hold right around 2 cords. 3.14 x 4 x 4 x 6 = 301.44 cu. ft. A cord is technically 128 cu ft. Assuming it holds exactly 2 cords that's 15% loss due to curvature and also for the loose stacking I do in the center (typically oddballs, shorties, uglies) and so that sounds about right to me.
    Boogeyman and mat60 like this.
  2. LordOfTheFlies
    LordOfTheFlies
    NY
    Well it happened to me today. Went outside after 3 days of rain and wind and noticed stack #18 partially collapsed. I did build it on a slope and didn't pay enough attention to the angle.......and this is what happened.
    Took about 40 minutes to restack.
  3. chris
    That will happen just from shrinkage as the splits dry out
    LordOfTheFlies likes this.
  4. LordOfTheFlies
    LordOfTheFlies
    NY
    Perhaps but not in this case. It was the slope and my lack of attention. It hasn't happened to any of the other stacks.
  5. buZZsaw BRAD
    mebbe it was an earthquake? There was one in Rhode Island the other morning...seriously!
  6. papadave
    All those wet leaves pushed it over...........:whistle:
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    I'd believe that if every stack were to have suffered the same fate. :thumbs:
    My landscapers have not been around.....and we have 50,000,000 trees here......so imagine how many leaves fall every fall!!!
    papadave likes this.
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    And if you can tell me what tree those red leaves are from I'll be impressed!
    buZZsaw BRAD likes this.
  9. buZZsaw BRAD
    cut some down :saw:and make more holz huasens! :stacker:
  10. buZZsaw BRAD
    deciduous!
    papadave and LordOfTheFlies like this.
  11. Rush Battle
    Rush Battle
    WNC
    Looks like Japanese maple to me.
  12. LordOfTheFlies
    LordOfTheFlies
    NY
    You win!
    Har har har
    The only tree I've cut down is a small japanese maple that got split in half lengthwise when the white oak snapped off. I don't cut down my own trees because I don't need to. That said, I just filed the permit to have the 2nd half of the white oak cut down.
    And stupid me before I knew my arse from my elbow I had two 75' red oaks cut down by a different tree service and they hauled away all that wood. :headbang:
    Rush Battle likes this.
