Your Least Favorite Wood?
Discussion in 'The Wood Pile' started by woody5506, Dec 7, 2017.
  1. Sean
    Sean
    I think it comes down to space and how available better wood is to you. The white pine is only marginally better than most spruce trees but I would keep it if I were you.
    Chazsbetterhalf and Horkn like this.
  2. Sean
    Sean
    Ive had this with my pine on my electric splitter a few times especially when I have a knot that the wedge is forcing open. Ive had a few sore knees over the years.
    FatBoy85 and Horkn like this.
  3. JPDavis
    JPDavis
    Prescott, AZ
    Wait what....?
    Oh geez..... I need to pay as much attention to my posts as I do in the field. It won't get me injured or killed, but it'll sure make me look foolish.
    Thanks for pointing it out and it won't happen again.
    Horkn and FatBoy85 like this.
  4. FatBoy85
    FatBoy85
    Washington State
    Don’t worry I won’t tell. :thumbs: Ive read posts and commented just to see that someone already did it like a year ago.:whistle:
    Horkn and JPDavis like this.
  5. FatBoy85
    FatBoy85
    Washington State
    Outdoor fire might help.
    If its been 3 years and at that mc% you think that might be solved with the splits being inside? Just a thought I keep a few under my stove for ease of the wood being ready to just put in the stove, they do start up well.
    Horkn likes this.
  6. FatBoy85
    FatBoy85
    Washington State
    Heavenly words bud!:eek: :D If you got that much passion to hate a tree I could see why some people try to eraticate this stuff by the metric giga-ton. :salute: Carry on!
    Moparguy and Horkn like this.
  7. Ashwatcher
    Ashwatcher
    West By God Viginia
    Walnut is at the very bottom rung of my admitted wood snob list-As others have said, 1) Messy 2) Medium heat at best 3) Ashes like sand and dirt...Lucky to live in hardwood heaven...I pick and choose and yes, I separate by species :smoke:
    FatBoy85 likes this.
  8. Moparguy
    Moparguy
    TN
    I guess the reason for my hate is, from what I understand about the tree, it's allelopathic and keeps the better trees from germinating and reproducing. I don't care so much that it smells like burnt power steering fluid and makes horrible firewood, but this sob just takes over if you let it at the expense of displacing most of the better trees.
  9. FatBoy85
    FatBoy85
    Washington State
    Power steering fluid! When you burn it or just as it sits in the ground?
  10. swags
    swags Moderator
    My least favorite would be walnut. It burns ok but leaves way too much ash. Two years ago I burned a lot of walnut and by the end of the year had made up my mind that I would not purposely go after any. I had a huge one that I dropped in my backyard. I got two 12’ logs out of it to mill and gave all the rest of the wood away. I’ve got plenty of firewood and did not need it. A guy that sells firewood ended up getting it so he didn’t care about what he was cutting.
    Chazsbetterhalf and Ashwatcher like this.
  11. sweet gum for splitting wise and black walnut burning wise
  12. mike bayerl
    mike bayerl
    Black gum. Horrible.
    jrider likes this.
  13. SammyWhammy
    SammyWhammy
    Blue Earth Minnesota
    I can’t believe there has not been a comment yet to wind people up..... that being said my 3 least favorite woods are: locust, oak and ash.
    red oak likes this.
  14. red oak
    red oak
    I’ll trade you gum, sycamore and elm for those 3!
    Since I split by hand and am years ahead I won’t even take those 3 anymore - unless the rounds are small enough to go in the stove without splitting. Least favorite to burn would be tulip poplar and black walnut.
  15. Buck55
    Buck55
    Rochester, NY
    Box Elder, Silver Maple, Willow and Cottonwood. For me, just not worth the effort for the results. I am fortunate to have access to plenty of higher btu content firewood.
  16. mike bayerl
    mike bayerl
    Red maple and poplar definitely get me through the times when I have to wait for my oaks to dry. Abundant, easy to split, fast drying but low BTU. Not the best, but not the worst.
  17. blujacket
    blujacket
    Kettering, OH
    Catalpa. Worst wood I ever tried to burn. Stinks like poop too
    Chazsbetterhalf likes this.
  18. Eric Wanderweg
    It used to be Catalpa for me but Quaking Aspen now takes the cake. I had some dry splits of it that barely burned in the outdoor pit, they just smoldered for a while until I threw plenty of better wood on top.
  19. iowahiker
    iowahiker
    NE Iowa
    I do not cut or carry basswood, popple (aspen), cottonwood, or walnut. None of these are any worse than the other, just my list of wood to avoid.
  20. yooperdave
    Basswood is low, aspen is low, any SPF and even Hemlock species is low, but the lowest for me is probably willow. I will not mess with that again. And, I primarily use a OWB!
    No sir.
    JCMC and Dakota Hoarder like this.
