Good wedges
Discussion in 'Chainsaws and Power Equipment' started by Yawner, Nov 3, 2020.
  1. Yawner
    Yawner
    Louisiana
    Can you someone recommend a good brand of wedges that are tough and will hold up? Last I bought must've been made in China, just pure junk, busted in first use.
    EDIT: I mean felling wedges.
  2. SAWMIKAZE
    SAWMIKAZE
    PGH
    I like K&H.
  3. MikeInMa
    Steel splitting wedges, or plastic felling wedges?
  4. Yawner
    Yawner
    Louisiana
    Sorry... felling wedges.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve got some black bear rifled felling wedges that I like. They have grooves on one side and ridges on the other so you can stack them without them sliding sideways as you drive them in. Ordered them from Bailey’s I think, only place I’ve seen em
  6. Monkeysocks
    Monkeysocks
    SE Minnesota
    I like these. The body is plastic but the head is metal so it holds up to hits.
    Chazsbetterhalf likes this.
  7. Sinngetreu
    Sinngetreu
    North Central Iowa
    I make my own out of UHMW plastic. They do ok, but they are easy on the saw.
  8. Yawner
    Yawner
    Louisiana
    I wonder why everyone doesn't use those instead of plastic!
  9. Homemade
    Homemade
    Wisconsin
    K&h the madsens factory brand and hardhead wedges work for me.
  10. Homemade
    Homemade
    Wisconsin
    The plastic is hard and brittle compared to a softer plastic. So if you miss swing, they have a higher tendency to snap in half.
  11. Yawner
    Yawner
    Louisiana
    I bought three wedges today, Archer 10" and they have grooves in them so that if you stack them to fell a tree, they stick together better to provide maximum lift. Decided to try, got a fair price.
  12. Nixon
    Nixon
    West Sunbury,Pa .
    K&H ,or double taper brand work as well as anything that I’ve used .
    gallery
    Winston and Chazsbetterhalf like this.
  13. thistle
    thistle
    Polk/Guthrie Counties,IA
    For many years I've just made my own out of local red/white oak,hickory or ironwood (Hophornbeam) on the bandsaw.Paint them hi vis orange usually,takes just a few minutes. Last at least 2-3 yrs minimum,when they split in half eventually or otherwise wear out in the kindling box they go.
  14. Yawner
    Yawner
    Louisiana
    If your home-made wooden ones last 2-3 years, that's amazing. Plastic ones I have owned don't!
    MikeInMa likes this.
  15. Dumf
    Dumf Banned
    K&H .
    More than two stacked ( grooved/riffled or not ) with the tree's weight on them can lead to a targeted groin hurt( polite talk ).
    They can shoot out with enough force to knock the H out of you . How do I know ? :hair::hair:
    Never tried wooden wedges....good idea, thx.
    MikeInMa and Yawner like this.
  16. metalcuttr
    metalcuttr
    western WA
    Might try these or regular construction wedges.
  17. Homemade
    Homemade
    Wisconsin
    Anyone try sprinkling wood chips in between the two wedges. It helps them stay together and not spit out.
  18. Dumf
    Dumf Banned
    Nice idea, will try it.
    BUTT: would chips 'hold' the wedges from being thrown out ? Seems they wood just slide more.
    There's a lot of pressure on those wedges lifting the tree. I only use wedges with a lean or close directional felling.
    Usually control with bore cuts when needed, setting a back tab for the final cut. Besides, I have those "tiny tiny" 16" bars that come in handy for felling larger than 16" DBH ( DBH ! ) .:wacky::wacky:
    Quick sharpening in the lot, better control, excellent for those aging backs. Except for Western softwood loggers, pro loggers here, and those needing some testo long bars for image :MM:, longer bars make no sense
    for eastern felling.
  19. Dumf
    Dumf Banned
  20. Dumf
    Dumf Banned
