Napoleon NPS45 - Replacing the igniter
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Geek, Oct 7, 2020.
  1. Geek
    Geek
    This may be something simple but wanted to know if both side panels need to be removed in order to access the igniter and replace it?
  2. don2222
    don2222
    Salem NH
    Take off the right side after removing the damper rod. Then remove the convection blower and then remove the bolt that holds the igniter tube on the back of the firewall and unclip the igniter wires. Easy Peasy!
    Also clean the dust out of the convection blower while you are in there!!!
    See pics
    Geek, badbob and BHags like this.
  3. Geek
    Geek
    Thanks. I had finished the task and just removed the right side panel, I realize that removing the blower would've been better but didn't remove the blower.
    The wire connectors were a bit smaller than the original igniter, so I had to pry open them a bit to insert the other leads from stove.
    All working good, thanks.
    imacman likes this.
  4. Geek
    Geek
    Looking at your first pic, that must be an older stove? Mine doesn't have that damper rod....I guess it is done through the digital control panel buttons?
    imacman likes this.
  5. don2222
    don2222
    Salem NH
    Yes, this is the NPS-40 with the potted blue modules and knob controls. :)
    Any dust in the room blower?
  6. Geek
    Geek
    Yes sir.
    Although I didn’t remove it but cleaned well with a brush and a can of compressed air.
    imacman likes this.
  7. Geek
    Geek
    I realize that emails from the site keep going to Gmail spam folder, that’s why I never saw your previous reply.
    I have marked the emails as not spam but Gmail keeps sending to spam folder....grrr
    imacman and jtakeman like this.
