Quadra Fire 1200 igniter not heating up
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Chstewart, Oct 27, 2020.
  1. Chstewart
    Chstewart
    New York
    My pellet stove has two issues going on. the igniter is not heating up. I am seeing 36 ohms across the leads. I do not get any voltage reading when it trying to start. The other thing it is doing is it keeps feeding pellets as if it thinks it is a flame so it will just overflow the pot if I don't turn it off manually. I have checked the thermocouple and at rest it read 0 MV but if I put heat it up it goes up to around 30 Mvolts
  2. imacman
    imacman
    Denver, NC
    Emergency call to our resident Quadrafire Pellet Stove Monkey Master slvrblkk
    jtakeman, slvrblkk and badbob like this.
  3. slvrblkk
    slvrblkk
    Northampton, PA
    Do you have the stove on a surge suppressor? It "seems" most likely the control board is toast
    jtakeman, imacman and badbob like this.
  4. Chstewart
    Chstewart
    New York
    No I don't That is what i was thinking as well
    imacman likes this.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    Did the stove start doing that all of a sudden or did you have a power outage or anything?
    jtakeman and imacman like this.
  6. Chstewart
    Chstewart
    New York
    Was working fine two weeks ago temps had warmed up so have not needed it until the other night when this problem showed up. Haven't had any outages that I am aware of since last time it was on.
    jtakeman likes this.
  7. imacman
    imacman
    Denver, NC
    Only takes a split second surge to kill one of these boards. Regardless of whether you get it working with the existing parts, you really should have a surge suppressor. This is one a lot of us use...TrippLite UltraBlok....about $34 on 'Zon.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    No voltage on the igniter at start-up is already a board/triac issue...then the constant feeding of pellets is another issue. Ohm reading on igniter is ok but I don't recall ever getting 30 millivolts (I think usually 14-15mV ish) on the thermo's but you're getting voltage so that seems ok too. Unfortunately, it looks like a bad board. Just to be safe, I would definitely double check all wiring and make sure the igniter has no frays before you plug a new board in.
  9. imacman
    imacman
    Denver, NC
    Not any kind of expert on Quad's, but I seem to remember a lot of people saying that re-seating the control board/module can sometimes cure problems?
    SKEETER McCLUSKEY and jtakeman like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Good point Pete, it's worth a try.
  11. jtakeman
    I've had to clean the board contacts with an eraser to cure issues. Contact cleaner and a q-tip would also work.
