Meadow maintenance
Discussion in 'The Wood Pile' started by Chris from Sweden, Oct 26, 2020.
  1. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    My back yard I try to maintain as a typical swedish meadow. That means I remove the hay once or twice per year. When I do that I remove the nutrients from the soil and the tall growing grasses doesn't thrive. Flowers and herbs will like it better.
    In a meadow you can remove some trees for firewood. If you remove to much trees the roots will compost and provide the soil with to much nutrients. This winter I will probably remove a little to much because it's a bit to much shadow and it blocks my sunset view.
    Anyway I had one dead ash that I removed today
    tmp-cam-1671328983554936074.jpg tmp-cam-8620327506227852175.jpg tmp-cam-3043109213600224826.jpg
    Tomorrow start thinning out this birch grove.
  2. Slocum
    Slocum
    North Central Indiana
    Do you have the emerald ash borer?
  3. billb3
    I've never seen firewood stacked so successfully on such a steep slope.
  4. Stoveshamster
    Stoveshamster
    Long Island north Shore
    look at the picture sideways
    farmer steve and amateur cutter like this.
  5. Mag Craft
    Here is a copy of your picture. Some good looking firewood.
  6. thats a pretty lookin stack looks a bit neater than what i usually get/do
  7. Chris from Sweden
    Chris from Sweden
    Sweden Europe
  8. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    No. But it's a sickness that kills our ashes.
  9. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    Thanks!
  10. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    Today I removed two of the birches. One rather big one worth taking for firewood
    I guess it was slightly less than a face cord tmp-cam-5616477170745183943.jpg
    A customer in my job asked if I could fix a chopping block. tmp-cam-3607332686923839657.jpg
    Tomorrow I probably continue with my thinning of my birch grove.
  11. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    Today I had a little time to continue.
    7 trees. 3 of them was worth taking for firewood tmp-cam-3146583976577815789.jpg tmp-cam-8183788222277729961.jpg tmp-cam-2625693327708721446.jpg tmp-cam-3342300536503597321.jpg tmp-cam-5452295028887927084.jpg tmp-cam-740972649491540261.jpg tmp-cam-6700916395321082873.jpg tmp-cam-328291101644691540.jpg
    It's considered absolute best firewood around here in Sweden when birch is around 4 inches in diameter. Easy split and nice to handle.
    A little adding to my pile. The lighter coloured firewood on the left is from today. tmp-cam-1464636314255668869.jpg
  12. sirbuildalot
    sirbuildalot
    Mass
    Interesting that you stack all your wood bark down. I always stack, or at least try to stack mine bark up to prevent moisture getting to it, and speed up drying.
  13. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    I belong to the bark down crowd. Than when I'm ready with the stack I top cover it. For this single row stack I am going to use old clay tiles from a roof.
    But I do not know what's the best way.
  14. Chazsbetterhalf
    Chazsbetterhalf
    You said 7 trees and only 3 for firewood. What is wrong with the others? If they are small why don't you use them for kindling?
    amateur cutter and M2theB like this.
  15. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    Yes too small. For kindling I prefer Norwegian sprouse. I have more than enough of that stuff. tmp-cam-7697128017969163876.jpg
    My dad has a 5 acre sprouse plantation where I need to remove 3-4 cords yearly for the next 10 years.
  16. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    I had a few hours of. So what's a better way to spend it than cutting some firewood?
    49 rounds 12 inches a piece. Maybe you can help me figure it out how high the tree was in feet :whistle:
    Little by little it's adding up. A problem I have with this firewood is that I have no clue what to do with it.
  17. billb3
    12 inches is 30.48 cm
    hope this helps ....
  18. Timberdog
    Timberdog
    Az
    The hills in Sweden are really steep.;)
  19. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    Add 10 inches of treetop and 1 inch of stump it's a total of 18 meter or 60 inches. Which is the typical height of trees in Sweden.
  20. Chris from Sweden
    Chris from Sweden
    Sweden Europe
    We are definitely at different parts of the world. If I lived in Australia the stack would probably look like this tmp-cam-6660799875794790751.jpg
