Firewood cutters poem...
Discussion in 'The Wood Pile' started by Greg, Jul 12, 2014.
  1. Greg
    Greg
    Not sure how many of you have seen this, but every time I cut an ash tree with one of my friends, he is always mumbling "ash wood wet and ash wood dry, a king shall warm his slipper by" Funny, as I think most of what this says about the different species is true from my experience.
    Beechwood fires burn bright and clear
    If the logs are kept a year
    Store your beech for Christmastide
    With new holly laid beside
    Chestnuts only good they say
    If for years tis stayed away
    Birch and firwood burn too fast
    Blaze too bright and do not last
    Flames from larch will shoot up high
    Dangerously the sparks will fly
    But Ashwood green and Ashwood brown
    Are fit for a Queen with a golden crown
    Oaken logs, if dry and old
    Keep away the winters cold
    Poplar gives a bitter smoke
    Fills your eyes and makes you choke
    Elmwood burns like churchyard mould
    Even the very flames burn cold
    Hawthorn bakes the sweetest bread
    So it is in Ireland said
    Applewood will scent the room
    Pears wood smells like a flower in bloom
    But Ashwood wet and Ashwood dry
    A King may warm his slippers by.
  2. Well Seasoned
    I wish I read this poem b4 cutting up all this poplar... :)
  3. Drvn4wood
    Drvn4wood
    Greencastle, Pa
    I just want some more wood..
    Chvymn99 and concretegrazer like this.
  4. swags
    swags Moderator
    Funny I've never seen that before today and it popped up in my FB too. Pretty cool poem.
    Chvymn99 likes this.
  5. swags
    swags Moderator
    Has some minor errors in it:emb:
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Ha that's great!
  7. Grizzly Adam
    Grizzly Adam Guest
    I might get a print of this made for the hearth room.
  8. Gark
    Gark
    SW Michigan
    I need that king and queen's email address. To write and suggest a double wall insulated stainless flue liner for better draft. And thus avoid:
    "Poplar gives a bitter smoke
    Fills your eyes and makes you choke"
    LOL
  9. Backwoods Savage
    There are actually several versions. Here are some (some might also be a copy of what Greg posted. My apology). I think there may even be some duplicates in these. Sorry but I haven't taken the time to make sure of it. Some are very similar with only slight variations.
    Beech wood fires are bright and clear,
    If the logs are kept a year.
    Chestnut’s only good they say,
    If for long it’s laid away.
    Birch and fir logs burn too fast,
    Blaze up bright and do not last.
    It is by the Irish said
    Hawthorn bakes the sweetest bread.
    Elm wood burns like a churchyard mould,
    Even the very flames are cold.
    But Ash green or Ash brown
    Is fit for a queen with golden crown.
    Poplar gives a bitter smoke,
    Fills your eyes and makes you choke.
    Apple wood will scent your room,
    Pear wood smells like flowers in bloom
    Oak and maple if dry and old,
    Keep away the winter cold.
    But ash wood wet and ash wood dry,
    A king shall warm his slippers by.
    These hardwoods burn well and slowly,
    Ash, beech, hawthorn oak and holly.
    Softwoods flare up quick and fine,
    Birch, fir, hazel, larch and pine.
    Elm and willow you'll regret,
    Chestnut green and sycamore wet
    Beechwood fires are bright and clear
    Chestnut's only good, they say,
    If for long 'tis laid away.
    But Ash new or Ash old
    Is fit for a queen with crown of gold.
    Birch and fir logs bum too fast
    Hawthom bakes the sweetest bread.
    Elm wood bums like churchyard mould,
    E ' en the very flames are cold.
    With an incense like perfume.
    Oaken logs. if dry and old.
    Keep away the winter's cold.
    But Ash wet or Ash dry
    Beechwood logs burn bright and clear,
    If the wood is kept a year
    Store your Beech for Christmas-tide,
    With new-cut holly laid aside
    If for years it's stored away
    Birch and Fir wood burn too fast,
    Blaze too bright, and do not last
    Flames from larch will shoot up high,
    And dangerously the sparks will fly....
    But Ashwood green,
    And Ashwood brown
    Are fit for Queen with golden crown.
    Oak logs will warm you well
    That are old and dry
    Logs of pine will sweetly smell
    But the sparks will fly
    Birch logs will burn too fast
    Chestnut scarce at all sir
    Hawthorn logs are good to last
    That are cut well in the fall sir
    Holly logs will burn like wax
    You could burn them green
    Elm logs burn like smouldering flax
    With no flame to be seen
    Beech logs for winter time
    Yew logs as well sir
    Green elder logs it is a crime
    For any man to sell sir
    Pear logs and apple logs
    They will scent your room
    And cherry logs across the dogs
    They smell like flowers of broom
    But Ash logs smooth and grey
    Buy them green or old, sir
    And buy up all that come your way
    They're worth their weight in gold sir
    Logs to Burn, Logs to burn, Logs to burn,
    Logs to save the coal a turn,
    Here's a word to make you wise,
    When you hear the woodman's cries.
    Never heed his usual tale,
    That he has good logs for sale,
    But read these lines and really learn,
    The proper kind of logs to burn.
    Oak logs will warm you well,
    If they're old and dry.
    Larch logs of pine will smell,
    But the sparks will fly.
    Beech logs for Christmas time,
    Yew logs heat well.
    "Scotch" logs it is a crime,
    For anyone to sell.
    Birch logs will burn too fast,
    Chestnut scarce at all.
    Hawthorn logs are good to last,
    If you cut them in the fall.
    Holly logs will burn like wax,
    You should burn them green,
    Elm logs like smouldering flax,
    No flame to be seen.
    Pear logs and apple logs,
    They will scent your room,
    Cherry logs across the dogs,
    Smell like flowers in bloom
    But ash logs, all smooth and grey,
    Burn them green or old;
    Buy up all that come your way,
    They're worth their weight in gold.
    But Ashwood green, And Ashwood brown
