Snow Plows
Discussion in 'Everything Else (off topic)' started by yooperdave, Oct 21, 2020.
  1. yooperdave
    Narrowed down to two choices. Both are straight blades for a 1/2 ton; midweight plow.
    What I'm looking for is user/owner reviews of Snowdogg brand and Boss brand.
    Likes and dislikes and whether you would buy again. Thank you!
  2. unbidden
    unbidden
    RI
    Don't just look at the plow itself. Check the hydraulics setup and the mounting system. I have a buddy with a SD and he hated the mount.
    mat60, Chvymn99, brenndatomu and 3 others like this.
  3. Eric VW
  4. huskihl
    huskihl
    I’m a little bit opinionated on this, but it’s for good reason. I don’t have any experience with Snowdogg, but my dad and I have owned several Boss and Western plows over the years. My current Boss plow is a 9’2” V plow from 1996. It was used commercially on 25-30 residential driveways for the first 15 years on my dually, and since then I have only plowed about 6 driveways every year. It’s still in use today, although it’s getting a little bit sloppy. I’ve replaced a solenoid 2 times I believe, 2 springs, and 2 hoses. And about five years ago I removed the cutting edge and welded on some plate across the bottom because it had rusted out where it was boxed in. I had a Western straight blade that I had purchased new before this, and replaced or did work to nearly every part on it in the three years that I owned it (new motor, pump, solenoids, cylinders, and even the A-frame needed reconfigured where it snapped off twice). I will never buy another plow unless it is made by Boss
  5. unbidden
    unbidden
    RI
    I'm totally on board with what you say. I didn't want to bash SnowDogg but from what I've seen they are a personal paved drive plow option only. I'm a Fisher Plow guy, very heavy duty and the Minute Mount 2 hookup is fantastic. From what I've seen of Boss they are a good plow as well, throw Myers in the mix as also. However, the plow industry is kind of "regionally" oriented... given manufacturers have a good reputation in different areas of the country. It's a get what you pay for industry,,,,,, no doubt about it.
    mat60, Chvymn99, huskihl and 2 others like this.
  6. huskihl
    huskihl
    Plus he’s a yooper, western yooper at that. Boss is made in his backyard
    mat60, Chvymn99, brenndatomu and 2 others like this.
  7. Canadian border VT
    Uncle and brother plow.. one used Boss other used the clear see through plow on 1/2 ton cause it was lighter. Go with Boss
  8. yooperdave
    Yeah, sometimes you just need to hear it from others. The snowdogg is a heavier plow 12 ga compared to 14 ga. but I'm leaning toward the Boss.
  9. Warner
    I believe boss, Westin and Fisher all are all owned by the same company now. I installed fisher plows for a while, it seems once they changed hands quality went down hill fast. I have been out of the game for a year so things may have changed. Even so I would go with a fisher myself mainly because it’s what I know.
    Definitely satay way from anything designated a a homowner unit!
  10. DaveGunter
    DaveGunter
    Boss is a cooler name than snowdogg
    mat60, Stinny, brenndatomu and 4 others like this.
  11. yooperdave
    :rofl: :lol::rofl: :lol: :handshake:
    DaveGunter, brenndatomu and Chvymn99 like this.
  12. badbob
    badbob
    Snowdogg and boss,and most others make light,med. and heavy plows.Gotta compare like models.Also depends on what and how you are going to plow.Mine is an old HM9 meyer with a e-57h pump.
    mat60 and yooperdave like this.
  13. huskihl
    huskihl
    Western’s parent company bought out Blizzard and Fisher. Toro bought out Boss in 2015.
  14. brenndatomu
    We had a light duty Western plow on a Dakota for plowing a pretty good sized lot and private roads at work...never had problems with it...would still have it but we traded up to an F250 :dancer:(hated that Dakota) and the plow was not wide enough...have a commercial Western plow on the 250 now.
    No experience with Boss or Snowdogg...
    yooperdave and mat60 like this.
  15. huskihl
    huskihl
    When a Western hits a small clump of sod and folds over and refuses to lift back up because it’s laying lengthwise underneath your pickup, that’s when you sell it and buy a Boss.
    True story :picard::(
  16. Horkn
    Western, blizzard and Fisher are all owned my the same company. Blizzard and Western are made in Milwaukee. I think the fishers are made in Maine still though.
    Boss is owned by Toro, and made in Iron Mountain Upper Michigan
    yooperdave, mat60 and brenndatomu like this.
  17. jrider
    jrider
    When I was plow shopping, I went with the heaviest 8'6" one I could find for back dragging. Less likely to lift up and leave a bunch of compacted snow in places where you can't push in. For me that was a Fisher. Something to consider if you think you will have to do any back dragging.
  18. Stinny
    Have had 2- 8' Fisher plows on 2 dif trucks, and a 6' lightweight Fisher on a Jeep Wrangler... all were great.
    brenndatomu, yooperdave and mat60 like this.
  19. sirbuildalot
    sirbuildalot
    Mass
    Maybe I missed it, but are you only plowing your own driveway, or doing commercial plowing?
    Sometimes a lighter plow is better, for less wear and tear on the front end of the truck.
  20. badbob
    badbob
    Biggest problem with "new" plow owners,buying the wrong plow,using it wrong,and abuse.So many variables.
    Stinny, Jack Straw and yooperdave like this.
