moving large logs in a small forest
Discussion in 'The Wood Pile' started by Not_chip, Oct 21, 2020.
  1. Not_chip
    Not_chip
    Knoxville, Tennessee
    Im moving some logs, mainly to shore up a hillside trail I have, ive got one that fell, and shredded the stump, I cut it off where it bent the stump over, but to get it out of the woods i gotta rotate it almost 90 degrees, which is tricky, being thats its in a tight spot (Its about a 30ft long log) im gonna go out later (Hopefully) with a come along and try to turn it so I can drag it out, any idea's on how to help make this easier? Its on a steep hill, with LOTS of underbrush and thorns, gonna maybe have to get rid of some stumps before moving it.
    Any thoughts on a "More power puller"? I want to get the 3T with 35ft of amsteel blue, but $330 is a lot for a 14yo that has no job lol, but I think it might be worth it.
  2. MikeInMa
    Cut it into shorter lengths. Then use the comealong and haul them up on the path of least resistance.
    Cash Larue and Backwoods Savage like this.
  3. sirbuildalot
    sirbuildalot
    Mass
    I'm trying to envision what you are trying to do. Are the logs acting as a retaining wall on the low side of the trail?
  4. Not_chip
    Not_chip
    for what im doing, they gotta be as long as possible
    MikeInMa and Backwoods Savage like this.
  5. Not_chip
    Not_chip
    yes they are
  6. sirbuildalot
    sirbuildalot
    Mass
    What type of trees are the logs from? Some species will rot out fairly quickly.
  7. Not_chip
    Not_chip
    tbh I dont know, but its been laying there for 4 years without getting much rot at all, so it should be fine
  8. Backwoods Savage
    Pulleys are your friend. It is simply amazing how much more you can move by using even one pulley. Think snatch block.
    Mag Craft, cnice_37, Horkn and 3 others like this.
  9. sirbuildalot
    sirbuildalot
    Mass
    I agree with Mike. Cut them shorter. At least short enough that you can maneuver them around. May have to put in some vertical stakes at the joints, but it will work. How high are you trying to build it up, just one logs diameter?
  10. Not_chip
    Not_chip
    it is amazing how much they can do, but i only have a 4-1 set, and one lone pulley with a dynema sling (Loops on either end with the block on one end, so i can wrap it around logs) and i tried to pull this log with that, but its WAY to heavy, and its up hill, ill just have to save up i guess
    Backwoods Savage and MikeInMa like this.
  11. Not_chip
    Not_chip
    ill drag them to the trail, and start adding logs till she no longer sinks :D
  12. Not_chip
    Not_chip
    and i cant really put in stakes, 1: I dont have any, 2: This clay on my property is just about as hard as concrete, so driving stuff into it is a challenge
  13. JCMC
    JCMC
    Just outside of Shushan, NY
    Yes they are! A couple years ago I bought a self-releasing snatch block it is invaluable with the winch.
  14. Not_chip
    Not_chip
    idk if im reading "Self releasing" wrong, but I dont think its supposed to do that...
    brenndatomu and Backwoods Savage like this.
  15. Not_chip
    Not_chip
    UPDATE: I got the log turned and pulled up the hill, now for the tighter turn onto the trail
  16. JCMC
    JCMC
    Yes as the cable passes thru it the choker hits a lever and releases the cable. It wasn't cheap but it works very well for doing what your are trying to do.
  17. buZZsaw BRAD
    Any pics?
  18. Not_chip
    Not_chip
    I dont have any of the log, but i got the hard part done yesterday
    as for the more power puller;
  19. Not_chip
    Not_chip
    [​IMG] like this one?
    brenndatomu likes this.
  20. JCMC
    JCMC
    Same principal
    brenndatomu and MikeInMa like this.
