Marine motor info
Discussion in 'The DIY Room' started by papadave, Jul 9, 2014.
  1. papadave
    My brother has an old early 60's Thompson Searay (I think that's the model), with a marine Iron Duke 4 cyl.
    Motor is on an engine stand, and when we drained the oil today, it smelled like gas.
    He's wondering what it might cost for a rebuild kit, so I told him I'd ask around.
    The FHC DIY room came to mind first.
    We were quoted over $2000 for a rebuilt replacement.
  2. jtakeman
    Does it have an manual fuel pump mounted on the block? This was the common fuel in the sump issue that I recall with the iron duck's(sorry).
    The iron dukes were tough lil buggers. Could be fine if the compression is good?
    papadave likes this.
  3. papadave
    Ok, so maybe not such a big deal.
    Thought I took a pic of the fuel pump, but yeah, it's mechanical. Didn't pay attention how it might be driven.
    Best way to get compression test if on a stand?
  4. rookie1
    rookie1
    You'd need to rig up a stArter and crank it over to see compression. If it wasn't run long with diluted oil it may be ok. It's not like a car that runs every day. I guess you can do a leak down test also.
  5. papadave
    Is it possible to put the flywheel back on and put it back on the stand in order to rig up a starter?
    MasterMech likes this.
  6. MasterMech
    You can always do a cylinder leak down test as well. You don't need a starter for that one. I think Advance Auto or AutoZone will loan you a tester for free too.
    Neither the compression or leak down test will tell you if there are bad bearings in the bottom end but if the engine has compression, I would fix the fuel leak and run it on the stand if at all possible.
    papadave and jtakeman like this.
  7. jtakeman
    I agree, After you fix the fuel issue and change the oil, I'd try to Run it for a bit. I wouldn't throw 2K at it just yet!
  8. papadave
    Well, $2000 won't be put into it, that's pretty certain at this point.
    He's been asking how much I think a rebuild would cost if we did it. I suggested around $500 for a kit, plus or minus a few bucks.
    He'd need to buy a few tools as well.
    We plan to pull the pan to replace the leaky gasket, and while it's off, see if I can see any problems with the bores.
    Most of the bolt-ons will be replaced with new.
    Is it ok to pull the caps and check the bearings w/o tearing the motor down completely? We've considered doing a rebuild as a winter project, and although it could be fun, I'm not sure I want to.
    I'm going to suggest he get his hands on a manual, if possible.
  9. nate
    nate Banned
    Palmer, AK
    Sure, just torque them back down to spec.
  10. papadave
    Thanks nate.
    Now, to find a manual with that info.
    That can be my brother's job, as soon as I tell him.:headbang:
  11. jtakeman
    You could also check the bearings clearance with plasti-gage while your at it.
    pigpen60 and papadave like this.
  12. nate
    nate Banned
    Palmer, AK
    Also I wanted to mention that a gas smell in the oil isn't abnormal. In the old days with manual chokes it was pretty common. A carb running rich could do it as well, or if the motor doesn't get good and hot the normal oil vapors and moisture will collect too.
    I wouldn't worry too much about it unless the oil level has been going up (meaning the sump is filling with quite a bit of gas)
    I looked it up in Alldata just under a 2.5L auto engine (I'm 99% sure it's the same aside from cooling and exhaust manifold to the MercCruiser 2.5)
    The main bearing caps are 80 ft/lbs
    Big end rod caps are 33 ft/lbs
    Hope that helps. It's been many years since I've torn down a 2.5 but they are easy to work on and simple. Used in Jeeps, GMs, forklifts, boats, postal trucks, etc!
  13. papadave
    It's a 153 ci chevy from what I can gather.
  14. 343amc
    343amc
    Northeast Lower Michigan
    I thought (could be wrong) that the GM 4 banger blocks (used by Mercruiser) from that vintage were actually 3 liter displacement, but the block was based on the 153 CI auto block. A friend used to have a mid 70s Checkmate with a 3.0 Mercruiser. Not sure if that is what you have or if the specs are different. I don't know much about boats other than what my friends that have them tell me - they're holes in water that you throw money in. :)
    Edit - just googled and it looks like there is a 2.5 L Mercruiser as well as the 3.0 I was thinking of, but they're based off the Chevy 4 cylinder 153 CI block, not the Pontiac iron duke 2.5L 151 CI block.
    Edit again - guess there are also some Pontiac 151 based marine blocks also. Since I'm proving I know jack about boats, I guess I'll step aside and stop confusing the situation. :)
  15. nate
    nate Banned
    Palmer, AK
    Iron duke is a 151cu in. 153 cu in is also a GM built motor but not the same.
    The specs I gave were for the iron duke. I don't have any books for the 153. Used mostly in the 60s-70s, I think before the 151 came out.
  16. papadave
    If we end up tearing it apart, I can get #'s from the internal parts that may help tell a more complete story.
    Not sure that's gonna' happen though.
    There IS a 3.0 as well in the later years according to info I've found.
    Keep the info coming, it's all gooder.
